Dump Pipe agaisnt Radiator
Old Apr 27, 2004 | 12:01 AM
miketurbohonda's Avatar
Default Dump Pipe agaisnt Radiator
hey i managed to get a 2 1/2" dump pipe off my turbo but its hard up agaist part of my radiator core !
if i left it would it melt down my radiator?
if i wrapped dump pipe in heat exhaust wrap could it sit agaisnt the radiator then ok??
thanks for your help
mike
Old Apr 27, 2004 | 12:17 AM
B18CRacer's Avatar
Default Re: Dump Pipe agaisnt Radiator (miketurbohonda)
you dont want it too close to the radiator because it could just break it. show us some pictures and we can make suggestions
Old Apr 27, 2004 | 12:25 AM
Default Re: Dump Pipe agaisnt Radiator (B18CRacer)
its so tight i couldnt even get a pic of it a
its in a ZC DOHC turbo ef3 civic its very tight at front
its about two square inch's pushed up agaist it bending the fins
Old Apr 27, 2004 | 12:29 AM
B18CRacer's Avatar
i take it to a muffler shop and get it fixed.
Old Apr 27, 2004 | 12:31 AM
Old Apr 27, 2004 | 12:38 AM
B18CRacer's Avatar
yeah that is definately too close...take it to the muffer shop or get a new down pipe.
Old Apr 27, 2004 | 12:39 AM
so what will happen?
you wouldnt belive how useless shops are here i went to exhaust shops that all they do all day and they said they can't do it cause its to hard!! i manage to do it in 2" but i wasnt satisfied
they wont even try cause its to hard for them
Old Apr 27, 2004 | 12:42 AM
B18CRacer's Avatar
most likely your radiator is going to break and you are going to have a lot of coolant everywhere. you dont want to wait and see what happens.
Old Apr 27, 2004 | 12:44 AM
GSRrR's Avatar
is this the downpipe or dumtube from the wastegate? if its the downpipe, you can clock the turbo. maybe that will move the downpipe far away enough.
Old Apr 27, 2004 | 12:45 AM
that dont sound to good oh well thats my weekend plans sorted then
i might try get it at least 5mm away from it or 1/4" what ever it is in inch thing
Old Apr 27, 2004 | 12:47 AM
when you clock it only the compressor case will move cause exhaust side is bolted to manifold.
yeah its the dump pipe
thanks any ways
help is much appreciated
Old Apr 27, 2004 | 12:49 AM
GSRrR's Avatar
really? i never really looked at it. mine was all clocked and ready cuz i got it used. good luck
Old Apr 27, 2004 | 03:59 AM
m R g S r's Avatar
Default Re: Dump Pipe agaisnt Radiator (GSRrR)
The way you have that picture, it is not the dump tube. It is the downpipe, the one that comes directly off the turbine side of the turbo and bolts to your cat (or where the cat should be, if your running a test pipe).
Old Apr 27, 2004 | 09:49 AM
rollydc69's Avatar
can you just get the half style radiator from civic.
Old Apr 29, 2004 | 04:25 PM
Default Re: (rollydc69)
i could but i dont have much money left now but i dont wana go swaping radiators they quite a bit smaller to and i dont wanna reduce cooling etc... i dunno i'll just hit the down tube with hammer so it doesnt touch
Old Apr 30, 2004 | 04:04 PM
B18CRacer's Avatar
Default Re: (miketurbohonda)
is there a way to reduce the space from the down pipe and the radiator by adjusting the radiator brackets?
Old Apr 30, 2004 | 05:43 PM
Adriano's Avatar
Default Re: (B18CRacer)
why did you get a 2 1/2 inches? Just get 1 1/2 that should give more clearance.
Old Apr 30, 2004 | 05:56 PM
Think's Avatar
Default Re: (brryder)
to,
Don't forget about motor movment in the engine bay aswell, you wouldn't want it to breat the RAD. you could use a different Rad aswell maybe 2 smaller ones, depending on what the car is used for. what kind of room is under the bend?
cheers,
yarrow t
Old Apr 30, 2004 | 06:12 PM
Default Re:
hi
not much room any where but adjusting radiator brackets sounds real good tho.
yeah engine movement how much should i allow for that?
but changing it from 2 1/2" to 1 1/2" thats crazy!!!!
Old Apr 30, 2004 | 06:34 PM
B18CRacer's Avatar
Default Re: Re: (miketurbohonda)
do as much as you can
Old Apr 30, 2004 | 06:50 PM
project dc2's Avatar
Default Re: Re: (B18CRacer)
i think he ment downpipe not dumptube
Old Apr 30, 2004 | 07:41 PM
Default Re: Re: (project dc2)
oops me dumb
thanks for help guys i'll modify them brackets and see how i go
Old Apr 30, 2004 | 08:15 PM
XDEep's Avatar
why not just put a spacer in there in the meantime. wrap it up. try to tilt the radiator more. use a flex pipe and point it elsewhere temporarily. for the love of gawd fix it. i saw someone that had an open dump tube blowing directly on the radiator
Old Apr 30, 2004 | 11:08 PM
B18CRacer's Avatar
Default Re: Re: (XDEep)
let us know how it went?
Old May 5, 2004 | 01:51 AM
hey guys i fixed up pipe it was like 2mm away but then i thought stuff it and went and brought a eg half radiator
https://honda-tech.com./zerothread?id=855035
thanks for all the help guys
Soon2bH2b
Oct 30, 2008 07:37 AM
AirWaveGT
Nov 21, 2004 09:09 PM
handa
Jun 21, 2004 06:34 PM
Boosted Chemist
Jun 17, 2004 05:16 AM
01ITR#700
May 20, 2004 02:22 PM
