Drag Radial Users
Old Aug 13, 2003 | 04:42 PM
Pengo's Avatar
Default Drag Radial Users
how are most of u doing ur burnout? i've seen a guy roll thru the water, ebrake and do a second gear burnout and put down 1.9 60 fts. would there be any diff burning out in first as opposed to second? never had enough time to get the hang of launching on these BFGs
Old Aug 13, 2003 | 05:26 PM
1 2 NV's Avatar
Default Re: Drag Radial Users (Pengo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pengo &raquo;</TD></TR><TR><TD CLASS="quote"> roll thru the water, ebrake and do a second gear burnout and put down 1.9 60 fts. </TD></TR></TABLE>
Old Aug 13, 2003 | 07:40 PM
gitwidit's Avatar
Default Re: Drag Radial Users (1 2 NV)
If you roll through the water a little bit it will give you less resistance when you do a burnout in 2nd gear. The quicker they spin the hotter they get.
Old Aug 13, 2003 | 08:33 PM
Pengo's Avatar
Default Re: Drag Radial Users (GITWIDIT)
yea, i figured that, but then i thought maybe i could spin them more and faster in first. of course second is capable of more revolutions per second, but you'd have to hold it for awhile to reach that point where it spins more. dry burnout should be in 1st then right? i'm not sure if my torqueless car can handle second dry
Old Aug 23, 2003 | 09:25 PM
accordhybrid's Avatar
Question for you guys that have the BFG drag radials when you mounted them and then had them balanced what tire pressure did they balance them at?
Thanks
Accordhybrid
DIS-1
Oct 20, 2006 05:57 AM
integralactic
Jun 22, 2006 05:45 AM
PFSeg
Aug 5, 2004 08:23 PM
18G_prelude
Mar 26, 2004 05:31 PM
turboex
Sep 19, 2002 06:51 PM
