Doing a compression test need some info. TIA
Old 09-08-2003, 07:42 AM
underpressure02's Avatar
Default Doing a compression test need some info. TIA
I am doing a compression test on a ls/vtec with srp 9:1 pistons and crower rods. The head is off a 2000 Si B16 the bottom end is from a 98 ls. It has a drag turbo kit on it also. Not sure if that will affect the compression but wanted to give all the details. What should the compression numbers be? I am looking to maybe purchase this car but I want to make sure that it has good compression and in good working order. TIA
Old 09-08-2003, 07:43 AM
Jared's Avatar
Default Re: Doing a compression test need some info. TIA (underpressure02)
I would expect the compression to be in the 170 range, i'd also do a leak down on it as well.
Old 09-08-2003, 08:20 AM
Andrea's Avatar
180-200psi per cylinder is average.
KDawg08
03-07-2012 10:38 PM
88 civic
04-05-2009 03:21 PM
self_made
06-19-2005 12:36 PM
Quick Reply: Doing a compression test need some info. TIA
