Does this size sound right?
Old Jul 18, 2002 | 05:25 PM
freakie's Avatar
Default Does this size sound right?
there is a site: http://www.turbofast.com.au
where it simplifies the research one would normally do to find an adequate sized turbo. But let me know what your thoughts are on this outcome:
I avhe a H22a VTEC, planning on running only 6 psi and 8 psi max, as I dont want to resleeve the block (dont start argument about whether or not one needs to resleeve). The outcome on the calculator is :
Garrett T3 turbo 45 compressor and a 0.49 compresser A/R
Does this sound right to you guys?
at 8 psi the return match is: Garrett T3, 50 compressor and 0.63 A/R
any ideas or thoughts? comments about the calculator??
Old Jul 18, 2002 | 11:40 PM
freakie's Avatar
Default Re: Does this size sound right? (freakie)
all the knowledgeable people in here and no-one knows?
Old Jul 19, 2002 | 01:20 AM
Markaccord95's Avatar
too damn small. i have a stock block and i run a 54trim 63ar t3/t04e and it makes full boost by 3500rpm. either go with a 50,54, or 57 trim but keep the E housing and the 63 a/r exhaust.
Old Jul 19, 2002 | 05:37 AM
RGAZ's Avatar
New User
Default Re: Does this size sound right? (Markaccord95)
I agree with mark. Too small for the h22.
Go with the t3/t04e hybrid and 57 trim. You will enjoy the high rpm boost. Definitely the 60's a/r exhaust turbine.
I think that calculator does not have the maps for the hybrid turbos. It will use t3's all day long.
Randy
elpiar
Sep 6, 2005 08:01 AM
xtremeness101
Mar 28, 2004 08:01 PM
88ZCRX
Jun 4, 2003 04:21 PM
92HB_HB
May 9, 2003 09:35 AM
ludelvr
Oct 30, 2002 02:38 PM
