Does my oil drain line look ok to you? TIA
1 Post
Hey guys, after a great deal of research and waiting on fittings, i think i have my oil drain pretty good. Will it work ?
It is a td04 (stock wrx turbo) mated to an hf adapter, its a low hanging pair
1 Post
Re: (TurboCoop)
yea i know the fittings cost more than the manifold. Not quite more than the turbo, it is almost new condition (10-20k miles)...
I work of a steamfitting outfit and plan on using some of thier thread sealant on the threads and gasket to ensure a good seal...
My only concern is that the hose is a little "pregnant" by the brass fitting. It seems to have clamped good, has anyone ever had expereince with braided hoses and this before?
i used that turbo on my first sohc setup. i liked it alot, almost instant power and held it until about 120mph. surprised ALOT of people with that setup.
1 Post
Re: (2redstars)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2redstars »</TD></TR><TR><TD CLASS="quote">i used that turbo on my first sohc setup. i liked it alot, almost instant power and held it until about 120mph. surprised ALOT of people with that setup. </TD></TR></TABLE>
Thanks, the goal for this project is cheap fast and relable. I have been pretty patient with the build and taken time choosing parts. I hope it works
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej1wilcox »</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Thanks I liked watching your build, nice work
1 Post
Re: (Running925)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Running925 »</TD></TR><TR><TD CLASS="quote">should work without any probs, looks good.
One big problem tho..
Convert it to 5spd </TD></TR></TABLE>
The donor/mockup motor was from an automatic. The car it is going on is 5speed jdm d15b
looks mediocre.
The reason I say this is that it looks like the bend is so sharp that the braided hose appears to have flattened out just a little bit, that means you are bending it beyond its designed bend radius.
It may not cause problems, but I'd check on it periodically, especially once the hose softens up from the heat.
You may want to loosen the worm gear clamp and let the hose relax, and then retighten it...sometimes the hose wants to 'tweak out' a little when you are tightening the AN fitting.
1 Post
Re: (Speed Industry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed Industry »</TD></TR><TR><TD CLASS="quote">looks mediocre.
Thanks for the input, When installing i did just that. tightened worm clamp, then AN fitting, then released clamp and retightened. Is there any chance of failure if the hose is bent a little beyond its radius? What would be a better solution? I trimmed the barbed fitting to allow this much radius, yet the hose still looks a little pinched. Its pretty tight...
Again thanks everyone for the input
Re: (Civicman86)
i say you are good to go. im going on two years with a bulkhead setup with zero problems. stat-o-seals FTW
i wish my AN fittings still looked that good
BEEYOND
09-02-2004 01:08 PM
FOrSfEd
02-01-2004 04:33 PM
