does it matter where you place the wastegate?
is the drag set up ok or is it beter to ge the wastegate after the collector?
Re: does it matter where you place the wastegate? (ILOVEGIRLS)
IMO the drag position sucks *****. It really only feeds off one cylinder. Too bad that is the manifold I have to use.
Re: does it matter where you place the wastegate? (Slow_ass_4dr)
yeah,as long as it is not on one runner like the drag.i am having problems with it right now so i am building a new manifold and have a 40mm tial on the way.we will be putting the wastegate off of the downpipe as well.the drag set-up seems to be fine with small downpipe and intercooler(more restrictive) and low boost.when you increase boost and flow is when you will start seeing problems(at least i did).my wife's ls with drag kit at 8 lbs has no problems whatsoever.
Re: does it matter where you place the wastegate? (turbotypeR)
how much is your new manifold going to cost? can you guy shed a bit more light on how a wastegate works? i just knows that it relives pressure..but if you put on the downpipe..how does that work. thanks
New User
I think he means on the downpipe flange - most T3 turbines are ported for an internal wastegate which relieves pressure right after the collector; you can port out the downpipe flange to mount an external wastegate using that same location. It's an ideal spot, but on some installs space is too tight to do it right.
Re: does it matter where you place the wastegate? (dbman96)
i see. does anyone have pics of this setup or any other good setup other than the drag? thanks
Re: does it matter where you place the wastegate? (HXMan)
ok..thanks for the explanation. who makes good manifolds that wont crack and will retain all the acc like the drag manifold?
Absentmind
Mid-Atlantic (Sales)
09-29-2008 05:53 PM
