Does hallman pro boost controller work well??
Old May 21, 2007 | 04:51 PM
Pnoyej6's Avatar
* B A N N E D *
Default Does hallman pro boost controller work well??
Im currently boosting 7 psi tial wastegate on my drag turbo ls vtec setup. Im gonna dyno tuned this week and up the boost to 10psi. WIll the hallman work and not fluctuate?? I dont have the cash for electronic one, im running hondata btw. Anyone have experiences with hallman?
Old May 21, 2007 | 06:09 PM
hangac1093's Avatar
Default Re: Does hallman pro boost controller work well?? (PNOYLSV-T)
I have a hallman, My Tial WG has a 6psi spring, And I am at 11psi. It holds perfect.
Hallman FTW
Old May 21, 2007 | 06:41 PM
blackeg's Avatar
Default Re: Does hallman pro boost controller work well?? (hangac1093)
the hallman will work fine, i used one for over 30k miles
Old May 21, 2007 | 06:43 PM
bb_one's Avatar
Default Re: Does hallman pro boost controller work well?? (blackeg)
Another hallman user here. Very satisfied as well
Old May 21, 2007 | 07:16 PM
twkdCD595's Avatar
Default Re: Does hallman pro boost controller work well?? (bb_one)
used a hallman for a while here as well before I switched to an ebc.
worked great.
Old May 21, 2007 | 09:01 PM
mike93eh2's Avatar
im using a hallman pro mbc.. holds a rock steady 25psi!! with i think something like a 12-15psi wastegate spring.
Old May 21, 2007 | 09:51 PM
Pnoyej6's Avatar
* B A N N E D *
Default Re: (mike93eh2)
Wow. Nice. It looks like i should be holding 10 psi no problems then.
Old May 22, 2007 | 10:33 AM
Pnoyej6's Avatar
* B A N N E D *
WHERE DO YOU GUYS MOUNT YOUR HALLMAN ON EXTERNAL WASTEGATE?? ANY PICS GUYS??
Old May 22, 2007 | 02:09 PM
B18Flip's Avatar
Do you guys get any boost fluctuation with weather/temp changes?
Old May 22, 2007 | 02:14 PM
mike93eh2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PNOYLSV-T &raquo;</TD></TR><TR><TD CLASS="quote">WHERE DO YOU GUYS MOUNT YOUR HALLMAN ON EXTERNAL WASTEGATE?? ANY PICS GUYS??</TD></TR></TABLE>
huh?
Old May 22, 2007 | 02:15 PM
mike93eh2's Avatar
Default Re: Does hallman pro boost controller work well?? (B18Flip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Flip &raquo;</TD></TR><TR><TD CLASS="quote">Do you guys get any boost fluctuation with weather/temp changes?</TD></TR></TABLE>
nope. depending... sometimes the a/f will though.
Old May 22, 2007 | 02:20 PM
mike93eh2's Avatar
yup get the rx if youre running high boost.
Old May 22, 2007 | 03:36 PM
Pnoyej6's Avatar
* B A N N E D *
how do you guys install your hallman mbc any pics?? so the one line goes from mbc to turbo housing and the other line goes from mbc to the external wastegate line?? got any pics?
Old May 22, 2007 | 04:46 PM
mike93eh2's Avatar
one line to side port of wastegate and other line to a vacuum source.. mine is hooked up to the GE vaccum manifold.
Old May 22, 2007 | 05:59 PM
Pnoyej6's Avatar
* B A N N E D *
when you mean vacuum source, do you mean turbo housing????
Old May 22, 2007 | 06:27 PM
Pnoyej6's Avatar
* B A N N E D *
here is some pics. Let me know if i connected it right. Dont mind the mbc, its not mounted yet
Old May 22, 2007 | 06:48 PM
Pnoyej6's Avatar
* B A N N E D *
any 1?
Old May 23, 2007 | 05:03 AM
Pnoyej6's Avatar
* B A N N E D *
the other one line is connected on the turbo?
Old May 23, 2007 | 05:10 AM
twkdCD595's Avatar
Default Re: (PNOYLSV-T)
maybe this will help clarify.
http://www.hallmanboostcontrol...d.pdf
Old May 23, 2007 | 06:12 AM
93civic_sedan's Avatar
I had a Hallman on my DSM, it was fine.
Old May 23, 2007 | 07:51 AM
raceACCORDingly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PNOYLSV-T &raquo;</TD></TR><TR><TD CLASS="quote">when you mean vacuum source, do you mean turbo housing????</TD></TR></TABLE>
vacuum like what your bov is connected to.
Old May 23, 2007 | 08:46 AM
HiProfile's Avatar
Um, wow. I never knew people couldn't install one of these. You have read the FI FAQ, or at least that 'Bees and Goats' FI Guide, right? If you understand how FI works, you'll never ask that question again.
If you put it between the WG and turbo, you'll see slightly lower PSI (for the same setting), and it will vary based on the weather (fmic efficiency). If you put it between the WG and a vacuum source (anywhere on the intake mani after the TB), psi will always be the same, but the IAT's will change a bit based on fmic efficiency.
Old May 23, 2007 | 09:11 PM
Pnoyej6's Avatar
* B A N N E D *
Default Re: (Mr Wonderfull)
I installed my hallman and when I hit full boost and its only boosting 5psi. Wtf i feel loss of power. Is it normal for psi to drop when i install hallman, I was currently boosting at 7 psi. The adjustment was all the way to negative. I turn the **** a little to up it and bam back to 7psi. I guess, I will have to hit the dyno Friday nite.
Old May 23, 2007 | 11:44 PM
SD_Lurker's Avatar
HT White Ops
Default Re: (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">
If you put it between the WG and turbo, you'll see slightly lower PSI (for the same setting), and it will vary based on the weather (fmic efficiency). If you put it between the WG and a vacuum source (anywhere on the intake mani after the TB), psi will always be the same, but the IAT's will change a bit based on fmic efficiency.</TD></TR></TABLE>
He explained it to you are you neglecting to read?
Old May 30, 2007 | 08:30 PM
boosted98teg's Avatar
can u explaine all that to me without the abreviations (fmic, iat, fi, fi faq, tp) i have my mbc hook to the turbo and to the waste gate. but if u connect the vacuum end of the mbc to the intake mani wat do u do with the line to the turbo? r u talking about leaving the turbo connected to the side of the wg and hook the mbc to the vacuum on top the wg and then run to the intake mani? i have a turbonetics deltage wg
ExVtec
Dec 29, 2008 10:52 AM
Eklsv-t
Apr 6, 2008 08:08 PM
AZNracerx1989
Jul 18, 2005 10:12 AM
Wo-Nelly
Feb 23, 2004 01:28 PM
dwilson
Jan 23, 2003 09:48 AM
