Does GE Sandwhich adapter have two ports?
Old Mar 26, 2008 | 01:05 PM
totsie7944's Avatar
Default Does GE Sandwhich adapter have two ports?
My full race kit comes with a 'Y' to run my stock oil pressure and oil feed line, but I also have a oil temperature and oil pressure gauge I need to run. How would I hook up these gauges to the sandwhich adapter?
Old Mar 26, 2008 | 01:19 PM
RTW DC2R's Avatar
it has 1/8 npt and another larger port but I forget the size.
Old Mar 26, 2008 | 03:25 PM
stealthmode62's Avatar
Your oil temp sensor goes in the oil pan, so you're only another T from adding the pressure sensor. I would put it up on the firewall so it's easy to get to and you don't have 382 things off the block fitting.
Old Mar 26, 2008 | 03:40 PM
IN VTEC's Avatar
Default Re: (RTW DC2R)
It's a -8AN o-ring port, but it's also got an AN flare as well. You can use either adapter.
I would run the turbo oil feed line from the sandwich plate.
Use a -8AN flare to -3 or -4AN flare adapter on the larget port to feed the turbo.
Use a 1/8" NPT to -4AN flare adapter and some -4AN hose to feed the oil pressure gauge.
Place the oil temperature gauge in the oil pan.
The stock oil pressure sensor can stay in the stock location.
Old Mar 26, 2008 | 04:26 PM
Boostfed's Avatar
New User
Default Re: (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">It's a -8AN o-ring port, but it's also got an AN flare as well. You can use either adapter.
The stock oil pressure sensor can stay in the stock location.</TD></TR></TABLE>
balbowskie
Feb 17, 2012 06:47 PM
88crxhfb16
Jul 23, 2005 11:02 AM
Turbo_y8
Apr 21, 2005 04:23 PM
W O T
Jan 29, 2005 08:01 PM
Nextelbuddy
Jul 13, 2003 07:44 PM
