does aem ems have this one hondata feature?
Old 03-03-2004, 06:36 AM
Boostage's Avatar
Default does aem ems have this one hondata feature?
The boost cut feature that keeps you from overboosting if the WG fails? I see no mention of it at aempower.com
Old 03-03-2004, 08:23 AM
Boostage's Avatar
Default Re: does aem ems have this one hondata feature? (Boostage)
Old 03-03-2004, 09:02 AM
ChargedLude97's Avatar
It doesn't have something preset in there, but i'm sure if you post over on the aem forum there is a way to cut engine off through one of there user defined activated switchs and they could give you some insite on how to hook it up. Most people with the aem just scale above there desired boost range to where it gets really rich or so if it goes above there desired value. I'm sure Mase some others here and at the aem forum would be of more help with this though.
Old 03-03-2004, 09:06 AM
BlueSi2k's Avatar
Default Re: (ChargedLude97)
I'm sure theres a way to do it but I just set it up to trigger my check engine light if I go above a certain load.
Old 03-03-2004, 09:07 AM
Boostage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChargedLude97 &raquo;</TD></TR><TR><TD CLASS="quote">It doesn't have something preset in there, but i'm sure if you post over on the aem forum there is a way to cut engine off through one of there user defined activated switchs and they could give you some insite on how to hook it up. Most people with the aem just scale above there desired boost range to where it gets really rich or so if it goes above there desired value. I'm sure Mase some others here and at the aem forum would be of more help with this though.</TD></TR></TABLE>
never thought of that but I would rather that than just bucking hard from a boost cut. that would scare the crap out of me. thanks for teh reply
Old 03-03-2004, 09:11 AM
No problem, don't forget you can also do that with the timing, so pull some timing out of the top also.
Old 03-03-2004, 11:34 AM
Eviloliv3's Avatar
Default Re: (BlueSi2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueSi2k &raquo;</TD></TR><TR><TD CLASS="quote">I'm sure theres a way to do it but I just set it up to trigger my check engine light if I go above a certain load.</TD></TR></TABLE>
thats a smart idea, ill be sure to use that
rodimus
76
09-24-2008 09:07 AM
integlspwr2k
05-13-2005 08:04 AM
legendboy
10-25-2004 10:49 AM
11psiTurboSI
03-29-2004 06:45 AM
nuro
11-17-2003 09:58 PM
Quick Reply: does aem ems have this one hondata feature?
