Do you 3'' will be overkill for my setup?
Old Apr 6, 2005 | 04:43 AM
fastcivicboy's Avatar
Default Do you 3'' will be overkill for my setup?
Getting ready to install my little ihi turbo on my d16 and want to know if yall think a 3" downpipe would be overkill? I want the downpipe that's going to spool it up the fastest but this turbo is so small I feel a 2.5 might be more reasonable." Let me know yall's opinion is. I want my setup to be similar to a supercharger setup, no lag. I am going to be using a pretty high flowing manifold. I will take pics when I get home. Nick
Old Apr 6, 2005 | 05:22 AM
TurboCoop's Avatar
Default Re: Do you 3'' will be overkill for my setup? (fastcivicboy)
Match it to whatever the exhaust port size on the turbo is. It will be a lot easier to bolt it up and fit everything that way.
Old Apr 6, 2005 | 05:43 AM
Benjithx's Avatar
Default Re: Do you 3'' will be overkill for my setup? (jdog1277)
If you want it to spool as fast as possible theni would do 3" for sure. It might not make any difference over a 2 1/2" but then again if its worth doing its worth doing right. and if you did 2 1/2" you would always be asking yourself if it would be better if you had only gone with 3"
Old Apr 6, 2005 | 07:34 AM
Evanmb44's Avatar
you should run 3in. that way it is already there if you decide to put some bigger power out later on. and it will help your turbo spool a little faster
Old Apr 6, 2005 | 07:47 AM
Bailhatch's Avatar
Default Re: (Turboaddict)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turboaddict &raquo;</TD></TR><TR><TD CLASS="quote">you should run 3in. that way it is already there if you decide to put some bigger power out later on. and it will help your turbo spool a little faster</TD></TR></TABLE>
i agree.
Old Apr 7, 2005 | 08:04 AM
TurboCoop's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turboaddict &raquo;</TD></TR><TR><TD CLASS="quote">you should run 3in. that way it is already there if you decide to put some bigger power out later on. and it will help your turbo spool a little faster</TD></TR></TABLE>true
Old Apr 7, 2005 | 08:32 AM
s2kdre's Avatar
Default Re: (jdog1277)
just do 4 inch and be done with it.
Old Apr 7, 2005 | 08:40 AM
thanks
96 GSR-T
Aug 16, 2007 04:18 AM
YoungKadafi
Oct 17, 2006 11:35 AM
xtrec02
Jun 9, 2006 04:15 AM
Bense
Apr 7, 2006 05:24 AM
