Do I need head studs?
Old Jan 25, 2005 | 03:01 PM
  #26
Ri5e's Avatar
Default Re: Do I need head studs? (1SlowSi)
My friends motor made close to 400 WHP with the OEM headbolts. Daily driven car too...
Old Jan 26, 2005 | 08:47 AM
  #27
1SlowSi's Avatar
Default Re: Do I need head studs? (TurboSmart)
i guess everyone's motor is different. I think mine will hold up. Its strong and has given me no problems up to 102,000 and still counting. Isnt that alot of miles to have a turbo on?
Old Jan 26, 2005 | 09:05 AM
  #28
racinskittle's Avatar
Default Re: Do I need head studs? (DefiantGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DefiantGSR &raquo;</TD></TR><TR><TD CLASS="quote">stock head bolts aren't reusable? </TD></TR></TABLE>
Nope, the threads stretch. It's recommended to replace them every time they're out. You dont have to. Im sure you can get away without doing it. But it's not what's recommended. It's also recommended to replace the headgasket, but I reused it. I knew what kind of risk i was getting into. Reusing the stock headbolts would be the same.
Old Jan 26, 2005 | 09:17 AM
  #29
SOHC_MShue's Avatar
Default Re: Do I need head studs? (racinskittle)
you are one of the few lucky people to not have problems with the sohc blowing headgaskets. I can't even keep mine from leaking with arp studs
Old Jan 26, 2005 | 09:38 AM
  #30
tgreaves's Avatar
Default Re: Do I need head studs? (Turbo E 604)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E 604 &raquo;</TD></TR><TR><TD CLASS="quote">
I'd say you're lucky or have a gifted tuner. </TD></TR></TABLE>
Im planning to get 300whp on a stock block.. Im a tuner and people tell me im a gifted tuner but I just tune..
On a side note I would surely get arp head studs while you have it apart.. Ask Bauleycivic what happens when people tell you to get arp head studs on a boosted motor and you dont..
Old Jan 26, 2005 | 09:45 AM
  #31
DaX's Avatar
DaX
Loved
Community Favorite
I was experiencing stretching of the OEM headbolts @ 7psi and blew my headgasket on my turbo LS. I had the head deck checked for square and it was warped a little. The shop removed 0.003" of material and cleaned the head for $65. I'm installing ARP studs with a fresh OEM headgasket and retuning for 10psi.
Old Jan 26, 2005 | 10:38 AM
  #32
11psiTurboSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racinskittle &raquo;</TD></TR><TR><TD CLASS="quote">
Nope, the threads stretch. It's recommended to replace them every time they're out. You dont have to. Im sure you can get away without doing it. But it's not what's recommended. It's also recommended to replace the headgasket, but I reused it. I knew what kind of risk i was getting into. Reusing the stock headbolts would be the same.</TD></TR></TABLE>
There not stretch bolts... I've call 1 Acura and 3 Honda dealership's parts department and none of the guys have sold head bolts and even there mechanics use the same ones.
Old Jan 26, 2005 | 01:30 PM
  #33
Turbo E's Avatar
but are the mech's at honda beating the crap out of their cars like us?
Old Jan 26, 2005 | 02:00 PM
  #34
Default Re: (Turbo E 604)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E 604 &raquo;</TD></TR><TR><TD CLASS="quote">but are the mech's at honda beating the crap out of their cars like us?</TD></TR></TABLE>
All I'm saying is that oem headbolts are reusable... not that there good for massive amounts of hp.
Old Jan 26, 2005 | 06:12 PM
  #35
1SlowSi's Avatar
Default Re: (11psiTurboSI)
So is it not safe at 300whp because of the power or amount of boost? Cause thats only 12-13psi.
Old Jan 27, 2005 | 05:37 AM
  #36
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 11psiTurboSI &raquo;</TD></TR><TR><TD CLASS="quote">
I reuse my oem headbolts and made 340hp with no problems.</TD></TR></TABLE>
Old Jan 27, 2005 | 09:12 AM
  #37
Burke's Avatar
Banned
dont care what your mechanic says. OEM Head bolts are torque to YIELD. meaning you go past their elastic limit and they will be longer when you take them out after they have properly been torqued down.
read an elementary Book on the Strengths of Materials and you will see what i mean.
and depending on the material, things get really hairy once you get into the region of plasticity.
reuse headbolts if you want. I never will and will never recommend anyone to do so, especially if they are boosting the motor. i've already blown one motor doing so
Old Jan 27, 2005 | 09:26 AM
  #38
Default Re: Do I need head studs? (11psiTurboSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 11psiTurboSI &raquo;</TD></TR><TR><TD CLASS="quote">There not stretch bolts... I've call 1 Acura and 3 Honda dealership's parts department and none of the guys have sold head bolts and even there mechanics use the same ones.</TD></TR></TABLE>
There's a spec for them. If they're within spec, it's ok to reuse. But let's think. First how many of those mechanics are hooking up turbo's? Second, If there's a spec....they MUST stretch....like almost ALL headbolts. Hell even the ARP's have a point. (recommend no more than 15 uses)....... It's called fatigue strength. Stress vs Cycles.
Why would anyone risk it? Im sure you could probably get away with it though.
Modified by racinskittle at 6:45 PM 1/27/2005
Old Jan 27, 2005 | 09:31 AM
  #39
Some people can get away with it. But why would anyone risk it? Because you say so?. </TD></TR></TABLE>
I didn't say so... he ask if anyone made over 300+hp oem bolts and I stated I did... Btw I saw what you wrote "Do you want a ******* cookie?" and then you deleted it 2 seconds later slick!
Old Jan 27, 2005 | 09:32 AM
  #40
nonvtecD's Avatar
Retorqued my head bolts 3 times. Not running insane amounts of power but... 92 and up Honda bolts are not torque to yield, some older ones were. If you have never taken the head off chances are yours will still be good. Lots of things contribute to a blown HG. Some people have problems even after switching to ARP's. You can't lump everything into one category.
Old Jan 27, 2005 | 09:34 AM
  #41
Also, what psi are you running right now on your turbo?</TD></TR></TABLE>
11 psi
Old Jan 27, 2005 | 09:42 AM
  #42
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 11psiTurboSI &raquo;</TD></TR><TR><TD CLASS="quote">11 psi</TD></TR></TABLE>
How Ironic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 11psiTurboSI &raquo;</TD></TR><TR><TD CLASS="quote">I didn't say so... he ask if anyone made over 300+hp oem bolts and I stated I did... Btw I saw what you wrote "Do you want a ******* cookie?" and then you deleted it 2 seconds later slick! </TD></TR></TABLE>
lol you caught me. I guess it really doesn't matter. Idk what im bitchin about.... Hell, I shouldn't even be talking... I reused the damn headgasket and will again
Old Jan 27, 2005 | 11:11 AM
  #43
How Ironic
lol you caught me. I guess it really doesn't matter. Idk what im bitchin about.... Hell, I shouldn't even be talking... I reused the damn headgasket and will again </TD></TR></TABLE>
It's all good ... When I did my pistons and rods I was going to get ARP bolts, but at that time it was on national backorder and a waiting period of 1-2 months and I have to get the car out of the shop cuz there was only 2 stalls and my father needed both... But I did use a new oem headgasket
All in all for $100 I would buy ARP head studs!
Atomic_EF9
Mar 29, 2011 11:51 AM
snatchback
Jul 5, 2006 08:47 PM
bdicustoms
Aug 25, 2004 07:35 PM
1.8T_EG
Jan 9, 2003 08:24 PM
RTW DC2R
Sep 9, 2002 01:58 PM
