Do I need a gasket between a turbo and a downpipe?
Old Jul 1, 2003 | 08:36 AM
hoya_10fintec's Avatar
Default Do I need a gasket between a turbo and a downpipe?
... just as the topic says.. Sorry if the question was too obvious..
If I do need a gasket, where can I get one or can I just make one?
Thanks
Old Jul 1, 2003 | 08:37 AM
austrian type-R's Avatar
no gasket!!!!!
Old Jul 1, 2003 | 09:09 AM
mamaboy's Avatar
Default Re: Do I need a gasket between a turbo and a downpipe? (hoya_10fintec)
some peeps do some peeps don't...but if you want one you can get it at roadraceengineering.com
Old Jul 1, 2003 | 09:17 AM
Default Re: Do I need a gasket between a turbo and a downpipe? (mamaboy)
Go w/o an gasket, when it blows it is a pain in the butt to replace it every time. When you bolt it directly on, it will seal 100% and you don't have to worry about blown gaskets.
Old Jul 1, 2003 | 09:21 AM
Burke's Avatar
Banned
Default Re: Do I need a gasket between a turbo and a downpipe? (austrian type-R)
What about between Manifold and turbo and dump tube and wastegate????
Thanks
Burke
Old Jul 1, 2003 | 09:22 AM
cool.. IC.. Thanks a lot guys!!!
Old Jul 1, 2003 | 09:34 AM
Default Re: Do I need a gasket between a turbo and a downpipe? (Burke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burke &raquo;</TD></TR><TR><TD CLASS="quote">What about between Manifold and turbo and dump tube and wastegate????
Thanks
Burke</TD></TR></TABLE>
No gasket there. I got piston to valve hit, when my damn wg to dump tube gasket blows and the hot exhaust gases melted the timing belt cover and the belt jumped over the cam gears . Little damage n first place, but occurs big problem. This had'nt happend without an gasket.
Old Jul 1, 2003 | 09:54 AM
PM-Performance's Avatar
the only gasket i used is the turbo to the manifold. all the others will blow out garutneed.
Old Jul 1, 2003 | 11:24 AM
Burke's Avatar
Banned
Default Re: Do I need a gasket between a turbo and a downpipe? (itr206)
so a gasket between turbo and mani is a good idea, but **** the rest??
Thanks for your help
ps - sorry to steal your thread
Old Jul 1, 2003 | 03:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by austrian type-R &raquo;</TD></TR><TR><TD CLASS="quote">
No gasket there. &lt;-----------
I got piston to valve hit, when my damn wg to dump tube gasket blows and the hot exhaust gases melted the timing belt cover and the belt jumped over the cam gears . Little damage n first place, but occurs big problem. This had'nt happend without an gasket.</TD></TR></TABLE>
Could you be more specific? 'cause I got gaskets for:
-- turbo-mani, mani-WG, WG-dump tube flange...
which one do I NOT need?
Thanks
Old Jul 1, 2003 | 11:19 PM
You don't need any of them. I run all that without gasket.
Old Jul 1, 2003 | 11:26 PM
TRE_'s Avatar
austrain- you dont use any kind of sealant or ANYTHING? just metal to metal, and it all seals up fine? i've got a gasket in between my WG and manifold that i think is fucked... should i just take it out and put the wastegate on without anything there? sorry if this is getting redundant for you, i just need some definite clarifaction.
Old Jul 1, 2003 | 11:27 PM
Jdm_Rice_Monster's Avatar
Use the fire ring gaskets on your wastegate and dump, teh bolts will stretch and break before you blow that gasket. As for the down pipe if you use a gasket make sure its metal.
Old Jul 1, 2003 | 11:40 PM
Default Re: Do I need a gasket between a turbo and a downpipe? (Jdm_Fast_Orange)
yeah, it seals all, I got tired of changing out the gsket at the wg flanges, metall, copper, all blows after time. I never runned a gasket between turbo - manifold and never runned one between turbo - dp. Just go metal to metal.
Maybe it is does'nt seal 100% when the metall is cold, but after it gets hot it is okay. But I have this problem only at the manifold - turbo area.
If you run a gasket between manifold and turbo and it will blow, congratulation, cause you will have a few hours of shitty work.
Old Jul 2, 2003 | 07:17 PM
I have never blown the gasket between the turbo and mani. its metal, maybe its just me but I have never seen that. Wastegate gaskets that are made of crumby material, yeah, but there are some bad *** gakets that have a fire ring that work good, I never had a problem with them either.
Old Jul 2, 2003 | 07:20 PM
Flamenco-T's Avatar
metal gasket wil never blow, at least I have never seen it blow. It seatc between the two surfaces with the groove in between.
stan
Old Jul 2, 2003 | 09:00 PM
SweetChin's Avatar
Default Re: Do I need a gasket between a turbo and a downpipe? (Flamenco-T)
what gaskets do you guys use for the manifold to head???
will the stock one work fine
Old Jul 3, 2003 | 09:05 AM
Flamenco-T's Avatar
Default Re: Do I need a gasket between a turbo and a downpipe? (SweetChin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SweetChin &raquo;</TD></TR><TR><TD CLASS="quote">what gaskets do you guys use for the manifold to head???
will the stock one work fine</TD></TR></TABLE>
yes
Old Dec 24, 2005 | 08:19 PM
nfinitecc's Avatar
i
Old Dec 24, 2005 | 10:37 PM
Schister66's Avatar
Man U FTW
so you're just doing straight metal-metal contact?? I was thinkin of putting some high temp caulking on it....makeshift really thin gasket.....but i guess i might not have to1
bvilleteggy62
Oct 15, 2007 12:35 PM
JDM00SI
Nov 2, 2005 09:14 AM
DaX
Apr 4, 2005 08:34 AM
Ls1 FD3s
Jan 22, 2005 05:18 AM
4-banging
Mar 15, 2004 12:03 PM
