DIY Datalogging RPMs
Old Jun 5, 2003 | 06:59 PM
spike's Avatar
Default DIY Datalogging RPMs
Ok new idea for datalogging rpms.. i found that it is not as simple as you may think datalogging one wire.. because it is a pulsed signal.. now the next idea.. I am looking for incite on this because it is just an idea as of now. I am going to cut the end off of a timing light and record the voltage of when it gets a voltage.. then there must be some calculation to figure out how often the pulses are to determine RPMs.. the more pulses (spark plug wire getting voltage) the higher the rpms.. anyone try anything like this before? Thanks guys!
Old Jun 6, 2003 | 03:26 AM
spike's Avatar
Default Re: DIY Datalogging RPMs (spike)
anyone? I know there's a lot of DIYers out there!
Old Jun 6, 2003 | 03:34 AM
Crote's Avatar
Why don't you just put a frequency to voltage converter, on the pulsed signal from the distributer? it will give you like 0-5V for 0-8k rpm.
Old Jun 6, 2003 | 03:51 AM
spike's Avatar
Default Re: DIY Datalogging RPMs (Crote)
where do i get a frequency to voltage converter? And what is it exactly?
Old Jun 6, 2003 | 05:32 AM
EE_Chris's Avatar
National Semiconductor
LM2917 - Freq-to-Voltage converter
Old Jun 7, 2003 | 05:33 PM
ID_ten_T's Avatar
Default Re: DIY Datalogging RPMs (EE_Chris)
interesting. i wonder if this is something similar to the way that the pivot shift light reads rpm. great info. keep us updated. thanks.
keith1054
Feb 21, 2009 11:23 AM
masijdm
Dec 17, 2008 12:04 PM
Basically
Mar 3, 2007 09:50 AM
trutuner
May 25, 2003 06:37 PM
Answer
Audio / Security / Video
Oct 25, 2001 06:49 PM
