distributer issues
Old Dec 20, 2006 | 01:32 PM
jamesrocksd's Avatar
Default distributer issues
I think my distributer is going. Does anyone know the telltale signs of distributer malfunction. I got a 2.0 stroked gsr fully built im using hondata
Old Dec 21, 2006 | 06:17 PM
wshondaman's Avatar
Default Re: distributer issues (jamesrocksd)
take the cap off the dis. and check for shaft play/ or oil in the dis. symptoms you might notice is the engine not reving all the way up (kind of like hitting a rev limiter)
Old Dec 21, 2006 | 07:05 PM
xenocron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jamesrocksd &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know the telltale signs of distributer malfunction?</TD></TR></TABLE>
Massive misfiring...noise in the cap.
If your rotor shaft is bad that can potentially lock up which causes the whole intake cam to lock up which results in timing belt slipping multiple teeth which often isnt a good thing...
ECU Cel codes are a common sign the sensors in the distributor are bad or wearing too. Helms has good testing flow charts to follow.
preludacris
Oct 4, 2019 07:50 AM
Damon Reeves
Jul 9, 2007 11:20 AM
Kyoto now
10
May 26, 2006 09:13 AM
bleedblue94
Jan 5, 2006 06:40 AM
ice11honda
May 14, 2005 05:47 AM
