Engine problem
Old Jul 6, 2007 | 07:48 AM
Damon Reeves's Avatar
Default Engine problem
Driving home from work today, car began to lose response....Car has approximately 80k...stock C5 motor. Car would not rev past 4000 rpm...
Would this be my headgasket?
CEL did not flash either.
Old Jul 6, 2007 | 07:49 AM
Doostur's Avatar
Did your RPMS begin to go crazy? Seem boggy?
Old Jul 6, 2007 | 07:53 AM
RTW DC2R's Avatar
sounds like maybe you lost a plug or something. check plugs/wire/dist/cap/rotor.
Old Jul 6, 2007 | 07:55 AM
Default Re: (Doostur)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doostur &raquo;</TD></TR><TR><TD CLASS="quote">Did your RPMS begin to go crazy? Seem boggy?</TD></TR></TABLE>
The idling was operating normal.
It just seemed boggy when I accelerated full throttle....and would begin to rock back and forth when I go up to 3-4k rpms.
Old Jul 6, 2007 | 08:10 AM
D's Avatar
D
Default Re: (Damon Reeves)
cap/rotor. Replace.
Old Jul 6, 2007 | 08:26 AM
Comp97GSR's Avatar
Default Re: (D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D &raquo;</TD></TR><TR><TD CLASS="quote">cap/rotor. Replace.</TD></TR></TABLE>
check yer oil too
Old Jul 6, 2007 | 08:45 AM
jgirard's Avatar
Default Re: (RTW DC2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R &raquo;</TD></TR><TR><TD CLASS="quote">sounds like maybe you lost a plug or something. check plugs/wire/dist/cap/rotor.</TD></TR></TABLE>
That's what I was thinking. I actually had an 02 sensor go out on my cat and the car bogged for a little while and then it just died on me, so I don't think it's that.
Old Jul 6, 2007 | 08:58 AM
Ed 341's Avatar
Default Re: Engine problem (Damon Reeves)
When was the last time you replaced your fuel filter?
Old Jul 6, 2007 | 09:34 AM
itr1244's Avatar
Default Re: Engine problem (Ed 341)
if i were you i'd do these.
-replace fuel filter
-change spark plugs
-inspect the spark plug wires / replace
-clean air filter
-check oil/ check coolant
-check/replace cap/rotor
and if it's still bad. check compression ratio and maybe leak down
-do a valve adjustment.
-check timing
and.. it's probably not the headgasket. i dont know where you came up with that one ..
Old Jul 6, 2007 | 09:46 AM
allmotaR's Avatar
fuel pump?
Old Jul 6, 2007 | 11:36 AM
RTW DC2R's Avatar
im 99% positive this is ignition related. fuel pumps and filters wouldnt make the tach bounce between 3-4K.
Old Jul 6, 2007 | 11:38 AM
JjuuN R's Avatar
Default Re: (D)
A plug going out would give you a bad idle as well...
Old Jul 6, 2007 | 12:22 PM
dcdcdc's Avatar
Default Re: Engine problem (itr1244)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 &raquo;</TD></TR><TR><TD CLASS="quote">if i were you i'd do these.
-change spark plugs
-clean air filter
-check timing
and.. it's probably not the headgasket. i dont know where you came up with that one ..</TD></TR></TABLE>
would it also be in this order as well? my car is having similar problem.
Old Jul 6, 2007 | 02:00 PM
itr1244's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcdcdc &raquo;</TD></TR><TR><TD CLASS="quote">
would it also be in this order as well? my car is having similar problem.</TD></TR></TABLE>
if i were to put it in "order"
-check oil
-check coolant
-inspect the spark plugs /replace
-inspect the dizzy cap and rotor /replace
-inspect the injectors and clean it if necessary
-inspect the Throttle body and clean the butterfly ( most likely not related to this problem but if you haven't done it.. why not )
-check timing
Old Jul 6, 2007 | 02:28 PM
totsie7944's Avatar
def a ignition thing...a fuel filter would not cause this. put new spark plugs in a get back to us. if its not that, id try swaping out a dizzy with a friend and seeing if thats it. My car had this problem and it was dizzy related.
Old Jul 6, 2007 | 08:26 PM
rjgerolaga's Avatar
this happen to me last month. plugs pop out and nipple on denso plug keeps coming off. just replace your plugs, wire, caps, rotor and you're good to go.
Old Jul 7, 2007 | 06:30 AM
Default Re: (rjgerolaga)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjgerolaga &raquo;</TD></TR><TR><TD CLASS="quote">this happen to me last month. plugs pop out and nipple on denso plug keeps coming off. just replace your plugs, wire, caps, rotor and you're good to go.</TD></TR></TABLE>
The motor wouldn't rev past 3-4k rpm?
I'm planning to tune up the car today so hope this works.
Old Jul 7, 2007 | 11:52 AM
Default Re: (D)
Just got done replacing the cap/rotor...spark plugs..and spark plug wires...and car still does not want to rev past 4k rpm and bogs while getting up to 4k rpm....
Help.
Old Jul 7, 2007 | 12:38 PM
RTW DC2R's Avatar
could be distributor...my stock distributor took a crap one day on the dyno, but it would stop revving at about 5K and it would just bounce on 5K like it was a rev limiter. I still think its something ignition related. if you know someone with a B series OBD2 motor see if you can swap out the distro and test it.
just out of the blue this started happening? is it idling ok? or its been getting gradually worse? any modifications like VAFC or ECU?
Old Jul 7, 2007 | 12:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R &raquo;</TD></TR><TR><TD CLASS="quote">could be distributor...my stock distributor took a crap one day on the dyno, but it would stop revving at about 5K and it would just bounce on 5K like it was a rev limiter. I still think its something ignition related. if you know someone with a B series OBD2 motor see if you can swap out the distro and test it.
just out of the blue this started happening? is it idling ok? or its been getting gradually worse? any modifications like VAFC or ECU? </TD></TR></TABLE>
Yeah just out of the blues....It idles fine (consistently at 800-900 rpms)
I forgot to mention that I do have the VAFC hooked up to the vehicle..but have not adjusted/tweaked with the device yet.
Old Jul 7, 2007 | 01:41 PM
totsie7944's Avatar
i told you....swap a dizzy and report back. Im betting thats the problem.
Old Jul 7, 2007 | 01:44 PM
Default Re: (totsie7944)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totsie7944 &raquo;</TD></TR><TR><TD CLASS="quote">i told you....swap a dizzy and report back. Im betting thats the problem. </TD></TR></TABLE>
I have already replaced the spark plugs, spark plug wires, and the distrubitor cap/rotor.
But the problem still persists.
Old Jul 8, 2007 | 04:25 PM
Dave_B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Damon Reeves &raquo;</TD></TR><TR><TD CLASS="quote">
But the problem still persists.</TD></TR></TABLE>
Cap and Rotor are only parts of the Dizzy.
You still have the ignitor and the Cam sensor (which can only be replaced with another dizzy, ignitor though you can replace without a dizzy)
The reason trying another dizzy was suggested was to determine without you buying parts if that's your culprit.
So as mentioned... swap the dizzy and report back.
Old Jul 8, 2007 | 06:40 PM
DC2R_JOE's Avatar
Default Re: (Dave_B)
I bet its the COIL! I had the same problem in my Old gsr! the car would not rev past 4k, it only lasted 3days then stop running! But try someone elses dizzy first
Old Jul 9, 2007 | 11:20 AM
totsie7944's Avatar
Default Re: (DC2R_JOE)
yea I am talking about the entire dizzy, not just cap and rotor. It takes 2 mins to swap a dizzy, just mark the timing so its about right. Report back, but Im willing to bet thats the issue.
john457
18
Feb 15, 2007 04:46 PM
jdmeg9
Sep 5, 2006 02:53 PM
CA6VTEC
Apr 17, 2006 07:28 PM
stockegsix
Jul 28, 2005 06:16 AM
tour de france turbo
Aug 6, 2003 02:57 PM
