dissapointed!
Old May 27, 2003 | 07:00 PM
  #51
TurboDX's Avatar
Default Re: dissapointed! (94gsr4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94gsr4dr &raquo;</TD></TR><TR><TD CLASS="quote">
hmmm...not gunna pull the bs flag yet, but what is your set-up, and do you have any times or vids to substantiate these kills. Until then i am gunna have a hard time believing this.</TD></TR></TABLE>
truely i dont care if u beleive me.....i am running a drag III kit w, aem fpr, aem fuel rail, aem filter, bbk intake fuel pump, afc....and extras....plus the car only weights in @ 2100lbs......
Old May 27, 2003 | 07:36 PM
  #52
norcalcrx's Avatar
Default Re: dissapointed! (tegasaurus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegasaurus &raquo;</TD></TR><TR><TD CLASS="quote">
13.1 &gt; 12....
-ryan</TD></TR></TABLE>
That was at 9.5 psi. I am now running 11 psi and will be installing the 3 bar map sensor, arp head studs, y8 intake manifold and tuning for 15 psi next weekend.
Ill post more #'s and dyno sheets then.
  #53
M.A.R.C.'s Avatar
Default Re: dissapointed! (T-sohctec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-sohctec &raquo;</TD></TR><TR><TD CLASS="quote">
some people just don't wanna believe it.....
I was making 180WHP @ 6.5 PSI W/180ft/lbs to back it up.
Tourque owns! </TD></TR></TABLE>
damn good numbers for a DX. i'm sure i woulda made like about 5 less whp and way less torque @ 6.5psi
Old May 27, 2003 | 07:39 PM
  #54
EpDarks's Avatar
Default Re: dissapointed! (CivicRyda2k)
In my opinion, you should pop for Hondata...
It will run so much better, and the power gains will be there.
Ditch the exhaust and run open-DP, just for *****.
Old May 27, 2003 | 07:46 PM
  #55
M.A.R.C.'s Avatar
Default Re: dissapointed! (EpDarks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EpDarks &raquo;</TD></TR><TR><TD CLASS="quote">In my opinion, you should pop for Hondata...
Ditch the exhaust and run open-DP, just for *****. </TD></TR></TABLE>
yah iknow it will... all in due time... i'm changing my shitty old turbo first of all and going obd1. then somewhere along the line definitely hondata. And I like to run/dyno the car as I drive it on the street daily. Only after I've done that do i see what it can do with stuff like open dp. hehehe
Old May 27, 2003 | 08:22 PM
  #56
Hayasa15's Avatar
Default Re: dissapointed! (BoostedSOHC)
Well i think your problem is the bluebox and the lack of an intercooler. The key to any turboed car is the fuel management once you get that all together then i doubt you will be disappointed.
Old May 27, 2003 | 09:05 PM
  #57
FredoSP's Avatar
Default Re: dissapointed! (Hayasa15)
Intercooler isa MUST
upgrade the Downpipe (its too tiny, like my greddy one)
High flow cat (2.5" or 3")
Hondata S200
Boost @ 8 psi youll be fine
See my #'s with the greddy, i have to install a lot of stuff once my flex pipe comes, ill be sure to very close to 200whp by just opening the exhuast!! The greddy DP is like 1.9"
Old May 27, 2003 | 10:26 PM
  #58
BoostedSOHC's Avatar
Default Re: dissapointed! (FredoSP)
ooh im pretty sure my DP is 2.5 cause a 2.25 gasket would not fit on the end of it, i had to mash it on there. and im hollowing out my cat this weeknd, so yeah then ill have 2.5 all the way back, if not more where my cat is.
Old May 27, 2003 | 11:30 PM
  #59
eg6turbo's Avatar
dyno dyno dyno...the dyno never lies especially with wideband...check ur compression and see if ur car is good to start with...make sure u got all the plugs, fuel and get a boost gauge to see if ur holding boost...most kits spikes a lil so check everything out...read the sig and sohc turbo can own pretty damn well...7 psi i made 160whp and 150tq untuned...
Old May 29, 2003 | 03:22 PM
  #60
CptCorN's Avatar
elite is in your sig....go there and get that **** tuned...tomorrow...and then bring it to the mnsportcompacts meet this saturday...muhahahahaa...i would like to see it....dont get too many nice cars to look at here in this hick city (st.cloud)....so i gotta migrate to teh cities to see them....
Old May 29, 2003 | 03:34 PM
  #61
MikeExt's Avatar
New User
Well you do need some fuel management, what about getting a V-AFC, DSM injectors, resister pack and going to a dyno.
Old May 29, 2003 | 03:57 PM
  #62
leadtrum's Avatar
Default Re: dissapointed! (MikeCivette)
i had the apexi kit and even with an automatic i could walk on gsr's with i/h/e. its definately the lack of intercooler.
seriously its not gonna rip you out of your seat power but its scoots pretty well i'd say. as for me, i'm leavin the sohc turbo camp and goin dohc turbo. but sohc power forever yo
Old May 29, 2003 | 05:24 PM
  #63
'92SiHatch's Avatar
Default Re: dissapointed! (leadtrum)
boosted sohc!
Mines puttin down 146 whp and 140 wtq @ 5.5 psi, and most dohc's cant hang with me!!
Old May 29, 2003 | 06:15 PM
  #64
senpai's Avatar
I killed bolton GSR's with 6psi, no intercooler; I bet he has a slipping clutch
Old May 29, 2003 | 07:12 PM
  #65
Default Re: dissapointed! (maztur)
if i shift fast my car goes ERR ERR ERRR and bucks before it finally starts to accelerate! ahah its kinda wierd. i have to shift slow and slowly put my foot to thbe floor to get going in a hurry.
Old May 29, 2003 | 08:10 PM
  #66
norcalcrx's Avatar
It sounds like you don't have a blow off valve. Post your setup!
Old May 29, 2003 | 08:17 PM
  #67
Default Re: (norcalcrx)
apexi turbo kit
Blitz SSDD blow off valve
Greddy MBC
Greddy blue box
NGK bkr7e plugs
stock injectors
stock fuel pump
stock timing
i have an Intercooler but it is not on yet
also an obd1 conversion, P28 ecu
boost is at 5.5 psi but it rises to 6 in like 1-3rd gear. IF you want to know anything else let me know ill post it.
Old May 29, 2003 | 08:38 PM
  #68
norcalcrx's Avatar
Default Re: (BoostedSOHC)
What do your spark plugs look like?
Old May 29, 2003 | 09:40 PM
  #69
Racerage1's Avatar
try to use different plugs..i think you're running to cold of a temp
try your stock plugs and see if there's a difference
Old May 30, 2003 | 06:41 AM
  #70
Default Re: (Racerage1)
those are the plugs everyone told me to use! anyway, ill take a peak this weekend.
Old May 30, 2003 | 09:34 AM
  #71
omahaturbocivic's Avatar
Default Re: dissapointed! (b18b98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18b98 &raquo;</TD></TR><TR><TD CLASS="quote">Riding in one is different then driving one. When your driving one..your more in control and get used to it but when your just riding in one your not in control. I'm sure your car is fast. What is the setup consisting? </TD></TR></TABLE>
Thats very true. My boosted sohc feels like stock slow to me anymore because when im driving im just paying attention to driving and im used to it. I often wondered if my car is runnin right because it felt so weak sometimes, but then id run into a 5.0 stang or dsm on the street and realize it must be runnin decent, plus it still impressed my friends. However if I let my buddy drive while I ride, I can just sit back and enjoy and it seems like it pulls way harder, It pleases me everytime.
I say get rid of the cat asap. Also it might be worth a shot to try warmer plugs, I run the 6 series versus 7 on my sohc with no problems. Its only 8 bucks plus tax for a round of ngk coppers.
Old May 30, 2003 | 09:37 AM
  #72
Racerage1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedSOHC &raquo;</TD></TR><TR><TD CLASS="quote">those are the plugs everyone told me to use! anyway, ill take a peak this weekend.</TD></TR></TABLE>
well since you're at stock boost setting u should be fine with stock plugs
Old May 30, 2003 | 11:52 AM
  #73
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: dissapointed! ('92SiHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by '92SiHatch &raquo;</TD></TR><TR><TD CLASS="quote">boosted sohc!
Mines puttin down 146 whp and 140 wtq @ 5.5 psi, and most dohc's cant hang with me!!</TD></TR></TABLE>
Are you running the blue box?
Old May 30, 2003 | 12:01 PM
  #74
jinxproof99's Avatar
New User
Default Re: dissapointed! (fnananon)
i love these threads.
SOHC "hater".
Old May 30, 2003 | 03:33 PM
  #75
M.A.R.C.'s Avatar
Default Re: dissapointed! (jinxproof99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jinxproof99 &raquo;</TD></TR><TR><TD CLASS="quote">i love these threads.
SOHC "hater". </TD></TR></TABLE>
we still love you... it's ok... some of us can't afford dohc's (like meself)
