Difficulty of changing a tial 38mm wastegate spring?
I am curious as to how hard it is to change a 38mm wastegate spring. I have one that is to large and need to drop to a lower PSI spring like .4 bar or something. Anyway i am just curious as to how hard it is to change the spring.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgh99si »</TD></TR><TR><TD CLASS="quote">its a bitch, a little easier with three or four hands</TD></TR></TABLE>
very true , one or two extra hands will make it easier
i opened mine up the other day to find a 1bar spring
. i had a friend hold that **** tight, while i used a wratchet and took off the bolts. once you get down to 1 bolt left- you or your friend needs to hold that **** real tight. with help it took me like 2 minutes, and i was watchin tv at the same time
. semi off topic question and sorry if this is a thread jack, is there a specific torque we should use when re-tightening the bolts that hold the wastegate together???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg »</TD></TR><TR><TD CLASS="quote">is there a specific torque we should use when re-tightening the bolts that hold the wastegate together???</TD></TR></TABLE>
I'd like to know too. I have a 10psi spring and contemplating whether to downgrade??
accordfreak
Sep 10, 2003 04:37 PM
