Differential installation
Old Apr 25, 2004 | 07:56 PM
sneakypete's Avatar
Default Differential installation
What tools are needed to install a differental? This is my spare tranny and I want to learn how to do it that way I can install my quaife later down the road. This is a 1994 LS tranny. I'm just going to pull out the shattered diff and put another stock one in.
Old Apr 25, 2004 | 08:01 PM
philipwight's Avatar
Default Re: Differential installation (sneakypete)
you will need a 10mm, 12mm, 14mm, snap ring pliers, prybar(or standard screwdriever). It is pretty in depth, i would get a fsm and read up..... not too hard but takes some time.
Old Apr 25, 2004 | 08:04 PM
sneakypete's Avatar
Default Re: Differential installation (philipwight)
The snap ring pliers are used to seperate the housing right?
Old Apr 25, 2004 | 08:08 PM
integramic's Avatar
There is a full "how to" in the integra forums that helps with the full change.
Old Apr 25, 2004 | 08:11 PM
to get the countershaft seperate from the case opposite of the bell housing you have to unclip a snap ring and the countershaft drops dowm and you can lift the case off. The prybar or standard screwdriver is used to seperate the case
Old Apr 25, 2004 | 08:17 PM
sneakypete's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philipwight &raquo;</TD></TR><TR><TD CLASS="quote">to get the countershaft seperate from the case opposite of the bell housing you have to unclip a snap ring and the countershaft drops dowm and you can lift the case off. The prybar or standard screwdriver is used to seperate the case
I've gotten that far. I just need to get the pliers to unclip the snap ring. I've taken all the bolts that hold the casing together and pryed the casing apart about 2 inches.
sneakypete's Avatar
Default Re: (integramic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integramic &raquo;</TD></TR><TR><TD CLASS="quote">There is a full "how to" in the integra forums that helps with the full change. </TD></TR></TABLE>
Thanks, I'll take a look.
Old Apr 25, 2004 | 08:46 PM
Default Re: (sneakypete)
dont forget the two 12s and one 14 on the side.
mcmmotorsports
10
Dec 24, 2013 08:48 AM
blackep925
Jan 28, 2008 01:41 PM
Powered by VTEC
Jan 26, 2008 09:03 PM
pinoyboiwonder
20
Jan 25, 2006 07:48 PM
B18B EK
35
May 5, 2003 03:10 PM
