Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
FD Install?
Old Dec 18, 2013 | 04:42 AM
mcmmotorsports's Avatar
Default FD Install?
How long should a final drive install take, provided the trans is out of the car?
Old Dec 18, 2013 | 07:48 AM
dirty19's Avatar
Ridin Dirty in Cali
Default Re: FD Install?
Id contact Jame Ornelas at Synchrotech Transmissions (909) 592-5900
Talk it over with an expert before diving in.
Old Dec 18, 2013 | 09:45 PM
Mista Bone's Avatar
D Tranny Guru
You don't simply just install a FD without going through the rest of the tranny, night as well replace the ISB and seals while it is apart.
Without cleaning the case it would take 3-4 hours to do it right, sometimes even longer as I go over it a few times.
Old Dec 20, 2013 | 01:40 PM
Lo-Buck EF's Avatar
oh no. he found us. we're all dOOmed...
Old Dec 20, 2013 | 02:04 PM
Actually, look at my profile. Found you guys back in 2006. ;-)
Old Dec 20, 2013 | 03:10 PM
Lo-Buck EF's Avatar
almost OG
Old Dec 20, 2013 | 03:14 PM
almost OG
Almost. :-/
Old Dec 22, 2013 | 06:21 PM
preludeNApower's Avatar
Straight swap could be done in Nader an hour.
However like said above you should go through the tranny while its apart, replace bearings, seals, and properly shim the mainshaft and diff. As well as a good cleaning. 3-6 hours
Old Dec 23, 2013 | 03:54 PM
Aquafina's Avatar
Under 45 minutes in the pits.
2-12 hours doing it properly depending on the equipment you have available.
Old Dec 24, 2013 | 01:43 AM
GSaura's Avatar
I just installed a final drive, LSD, and carbon synchros. I already had the correct shims for the diff and the countershaft. It took almost 4 hours including a run to the parts store for gasket maker.
Old Dec 24, 2013 | 08:48 AM
kingofbattle909's Avatar
https://honda-tech.com/forums/transmission-drivetrain-127/b-series-transmission-teardown-rebuild-tutorial-2443459/
turbolshatch
Mar 17, 2009 08:51 PM
Rod.
Sep 22, 2004 03:11 PM
B18B EK
35
May 5, 2003 03:10 PM
Neptune
Dec 25, 2002 10:52 PM
boostedcvc
Nov 14, 2002 01:49 PM
