there is only one way to install dizzy,right?
cause the nipple of the dizzy can easily be turned by accident, and i need to make sure i dont accidently turn nipple of dizzy 180 degree and install it.
need this confirm. thanks.
Re: there is only one way to install dizzy,right? (pdotjones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdotjones »</TD></TR><TR><TD CLASS="quote">yeah its only one way to install it.....</TD></TR></TABLE>
x2!!
x2!!
Re: there is only one way to install dizzy,right? (Powered by VTEC)
You can install it both ways. I've done it. It slides on easy the right way and the wrong way you need force to get it on. So if it doesn't slide in easy you have it 180 degrees off.
Re: there is only one way to install dizzy,right? (Bob Dole!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob Dole! »</TD></TR><TR><TD CLASS="quote">You can install it both ways. I've done it. It slides on easy the right way and the wrong way you need force to get it on. So if it doesn't slide in easy you have it 180 degrees off.</TD></TR></TABLE>
thanks again. and it did slide in easy. so i think i got it the right way.cause i was trying to force it to get in. but it wont. but the other way around, it was easy.
Re: there is only one way to install dizzy,right? (speedooo)
They can be forced in the wrong way, seen it too many times from people trying to do their own repairs.
<edit > he said nipple
GDD's Dr. Phil?
the keyway is staggered, but not very much... it will go in and bolt up the wrong way with enough effort , trust me. Same friend did it twice on two different cars!
cmsrally
10
09-25-2005 03:22 PM
Touch
11
06-15-2003 01:24 AM
