high compression piston info
Old Oct 24, 2002 | 07:59 PM
gsrteg's Avatar
Default high compression piston info
Say if someone used high compression pistons somewhere around 11.5-12.5:1 c/r, would using cams designed for 10.0:1 make an engine have the same power as stock pistons? I am asking because I figured that larger comp pistons would create a more powerful explosion, but when the same amount of air/fuel is entering the cylinders with stock cams it would make using high comp pistons useless or should I say unnoticable over stock pistons? Correct me if i'm wrong.
Old Oct 24, 2002 | 11:56 PM
riceboy's Avatar
Default Re: high compression piston info (gsrteg)
more compression equates to more power, unless cam timing is comprimised or the specs of the cam are specifically designed form your application (which no off the shelf cam is)
Hy-wind
Dec 2, 2004 04:18 AM
sledgehammer
Nov 3, 2003 01:58 PM
sparknblaze
Aug 15, 2002 08:31 PM
StinkyTofu
Oct 22, 2001 09:30 PM
