Difference between Obd2a and Obd2b?
Old Jan 23, 2004 | 03:28 AM
S2KP's Avatar
Default Difference between Obd2a and Obd2b?
Does anyone know what the difference is between the two? I have a Skunk2 jumper harness currently hooked up to my 99Civic withan Obd1 ecu. I plan on using it on my 96Hatch....TIA
Old Jan 23, 2004 | 06:25 AM
PHiZ's Avatar
Default Re: Difference between Obd2a and Obd2b? (Turbo_Siii)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo_Siii &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know what the difference is between the two? I have a Skunk2 jumper harness currently hooked up to my 99Civic withan Obd1 ecu. I plan on using it on my 96Hatch....TIA</TD></TR></TABLE>
96-98 civics are OBD2A
99-00 civics are OBD2B
You don't really need to know the difference for anything do you?
-PHiZ
Old Jan 23, 2004 | 11:47 AM
S2KP's Avatar
Default Re: Difference between Obd2a and Obd2b? (PHiZ)
i know that but what are the diferences in the wiring?
Old Jan 23, 2004 | 11:48 AM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
interesting....learned something new today......
Old Jan 23, 2004 | 11:53 AM
Scott - 93HB Si's Avatar
Default Re: (dgonzals)
Yes, the connectors are different - well same connectors, but pins in different place. There are also a few more sensors on OBD2b that don't exists on OBD2A (regardless neither of them are used by the OBD1 ECU).
You will need an OBD2a Jumper to use the OBD1 ECU in a 96 car.
Old Jan 23, 2004 | 12:33 PM
99blackcivicSi's Avatar
Default Re: (Scott - 93HB Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scott - 93HB Si &raquo;</TD></TR><TR><TD CLASS="quote">(regardless neither of them are used by the OBD1 ECU)
please explain this??? because as far as i am concered that is BS.
Old Jan 23, 2004 | 04:39 PM
808b18c1boosted's Avatar
it wont work with a 96-98 civic. the major difference is the connectors.
Old Jan 23, 2004 | 04:45 PM
Sonny's Avatar
Default Re: (99blackcivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackcivicSi &raquo;</TD></TR><TR><TD CLASS="quote">
please explain this??? because as far as i am concered that is BS.</TD></TR></TABLE>
There are a few OBD2 specific sensors such as the Crankshaft Fluctuation Sensor (CKF) that are used by the OBD2 ECU that won't be used by the OBD1 ECU.
Sonny
Old Jan 29, 2004 | 08:17 AM
That Dood's Avatar
Default Re: (Sonny)
OBD2b uses the 'A' 'B' and 'C' plug and OBD2a uses 2 of those and the 'D'....your better off just finding someone to swap ya harnesses....
About sensors...depending on what model...but 96-98 some models dont have a gas tank pressure sender...which would be your only concern...IF you were trying to run a OBD2b ECU...
if youre using OBD1...then the only thing you have to worry about is primary O2, fuel injectors (I think....).
I am too curious if I am gonna have to run different injectors and such...I am going to run a chipped OBD1 ECU in my 00...hmm...anyone else can help?
Old Jan 29, 2004 | 08:33 AM
HXMan's Avatar
Default Re: (That Dood)
if you use an obd2 to obd1 harness you only need the harness and the obd1 ecu.
You don't need different injectors, distributor, etc.
Old Jan 29, 2004 | 08:46 AM
That Dood's Avatar
Default Re: (HXMan)
tight...
Dukie432
Jan 13, 2009 07:08 PM
bvilleteggy62
Sep 20, 2007 06:09 PM
mrkdky
Dec 24, 2004 01:37 PM
tommy b
Jul 24, 2003 05:08 AM
F00LI0
Jul 18, 2003 12:36 AM
