Difference between the 2 XS mbc's?
Old Jul 21, 2002 | 01:58 PM
ceemarun's Avatar
Default Difference between the 2 XS mbc's?
what is the difference between the two XS manual boost controllers? theres one for around $80 and another "high performance" one for $140ish. im assuming one is way better...prevents for spikes or something. thanks.
Old Jul 21, 2002 | 02:05 PM
JM Performance's Avatar
Default Re: Difference between the 2 XS mbc's? (ceemarun)
i think ones bleed and the other isn't
Old Jul 21, 2002 | 02:06 PM
ceemarun's Avatar
Default Re: Difference between the 2 XS mbc's? (00SilverLS)
both prevents spikes just as well?
Old Jul 21, 2002 | 04:08 PM
SIK IN DA HED's Avatar
New User
both do not prevent spikes. the standard mbc is the bleeder type. the high performance mbc is the ball and spring design... which i recommend. dude... get the joe p mbc on http://www.boostcontroller.com for only $50 shipped. i got one and it works pretty good. does the same thing as the XS hpmbc, but it has a dual ball design as a safety feature for overboost. for the amount of boost youre doing.. you wont get any boost creep with the joe p mbc and it helps the turbo spool quicker... especially in 5th gear.
Old Jul 21, 2002 | 05:08 PM
biassj's Avatar
The dual stage comes with a toggle switch to switch between boost. Thats basically the only difference.
Old Jul 21, 2002 | 06:23 PM
turboex's Avatar
Default Re: Difference between the 2 XS mbc's? (biassj)
what is faster for spool up out of the two? does anyone know? also i have the dual stage one from turboxs and it does not have the same part. ball and spring as the high performnce one.
1sic3dr
Mar 16, 2007 05:12 PM
turbochargeb18c
Feb 21, 2006 11:56 AM
SleepersOwn
Jan 1, 2006 05:32 PM
microsoft_sux
Jan 21, 2005 09:15 PM
ceemarun
May 30, 2002 03:12 PM
