THE ULTIMATE BUILT MOTOR FOR BOOST
Old Aug 20, 2010 | 06:23 PM
x still jaded x's Avatar
Default THE ULTIMATE BUILT MOTOR FOR BOOST
I have the ULTIMATE MONSTER MOTOR BUILD for sale also $5k FIRM
TEXT ME if you have questions
#317-408-5206
Darton MID sleeved B16B block @ 84mm w/ copper o-rings
ERL 5-main girdle w/ arp studs
Scat 95mm Crank
Crower billet rods
CP 9.7:1 pistons
Custom Cometic MLS headgasket
1/2" ARP head studs w/ custom dowel pins
b16 head ported and polished, combustion chanmbers de-schrouded to 84mm
manley inconel exhaust valves
manley stainless steel intake valves
supertech dual coil springs
supertech titanium retainers
Comp stage 4 turbo grind cams
NEW OEM PARTS:
oil pan 10an return bung tig welded to pan
oil pickup
oil pump
water pump
timing belt
tensioner
tensioner spring
tensioner bolt
H22 LMAs
camshaft seals
front and rear main seals
sidecover
sidecover gasket
valve cover gasket
oil pump pickup gasket
oil pump o-ring
main and rod bearings
thrust washers
cam gear keyways and bolts
oil pump bolts
water pump bolts
ALSO HAVE A BRAND NEW PORT MATCHED EDELBROCK IM and IM GASKET go with motor
ALSO HAVE A EXEDY HYPER SINGLE slightly used for $500
Old Aug 20, 2010 | 06:24 PM
Default Re: THE ULTIMATE BUILT MOTOR FOR BOOST
i also have:
TONS OF STUFF...like it says...PLEASE DONT CALL ME, if i dont recognize the number i won't answer. I'm usually working, and i CAN NOT TAKE CALLS AT WORK! if you need to get ahold of me the FASTEST AND EASIEST WAY IS THROUGH TEXT! #317-408-5206
99-00 civic SI steering wheel w/airbag and sensors $200 obo also have pass.side bag w/cover
99-00 civic NOT SI headlamps slight scratches $40
MSD 6462 6 series ignition box w/boost timing $200 obo
MSD blaster coil and ignition wires attached to B series Diz $200 obo
b16 IM w/sensors and fuel rail/regulator $125
sorry for the crappy pix
Old Aug 21, 2010 | 02:52 AM
bump
Old Aug 21, 2010 | 02:53 AM
the bumps will come.
Old Aug 21, 2010 | 04:51 AM
cerealjoe's Avatar
That housing looks good and interesting. Is there any discount for it?
Old Aug 21, 2010 | 05:18 AM
rey_boricua's Avatar
bump
Old Aug 21, 2010 | 07:48 PM
i love all the spam bumps i get on here now...wtf?
Old Aug 21, 2010 | 08:20 PM
porkythegrunt's Avatar
God damn, great prices man. Glws.
Old Aug 22, 2010 | 05:31 AM
thanks, i can't believe i haven't got any serious offers...couple RIDICULOUS low ball ones.
Old Aug 22, 2010 | 09:59 AM
mikeyg123's Avatar
damm if i wasnt scared to make payments overseas for this i would buy it very quickly
Old Aug 22, 2010 | 10:25 AM
haha...not to mention the cost of shipping across the planet!
Old Aug 22, 2010 | 04:23 PM
s10cky's Avatar
What are the specs on the turbo, 4 or 5 bolt?
Old Aug 22, 2010 | 06:27 PM
4 bolt .82AR precision gt35r no shaft play polished housing 5-7k miles on it
Old Aug 23, 2010 | 01:48 AM
bump before work...
Old Aug 25, 2010 | 03:31 PM
the turbo and motor mounts sold...but still have the rest...i can't believe no one wants a motor that can EASILY SUSTAIN 800WHP.....come on now...this was my dream build and i'm losing 4k on it...it needs a good home!
Old Aug 27, 2010 | 05:07 AM
man, wtf...no one wants this thing?! weird...
Old Aug 31, 2010 | 01:55 PM
wtf?! no one wants to make 800+whp?
Old Sep 1, 2010 | 12:51 PM
PapioGXL's Avatar
Bump for good seller. Great communication, and quick shipping.
I realize I am a new member to this forum, but I'm on many other, mainly rx7club.com
Old Sep 5, 2010 | 11:43 AM
buuuuuuuuump
Old Sep 7, 2010 | 04:05 PM
bumpin
x still jaded x
Sep 7, 2010 05:19 PM
laziebun
Nov 4, 2007 04:57 PM
turbogsr18
Dec 15, 2006 05:29 PM
ludesleep
May 12, 2003 10:13 PM
hatchy
Apr 5, 2002 04:01 PM
