Did I forget anything?
Well as soon as I sell the bike this project will begin. I am sitting down and figuring up cost of everything and I think I've got everything nailed. Chime in if I missed anything. Plan on running 6-8psi street and 12-14 track.
Full-Race turbo kit with T3/60-1, Carsound 3" cat or TP, Thermal 3", NGK colder plugs, Walboro 255 high pressure, RC 550's, STR fuel rail, B&M fpr, STR cam gears, portflow spring & retainer package, ferrea valves, possibly GSR cams or maybe GSR/ITR combo, JE 9:1 pistons stock bore, Eagle rods, ARP hardware, playing with the idea of STR block guard not to sure if I am keen on block guards yet, Hondata s200 w/ boost and 3-stage rev control w/ a P28 ECU, PWR radiator and maybe a FAL, solid motor mounts. Only other pieces I am considering are STR t/b and intake manifold although I already have an ITR t/b and ITR intake manifold on the car so I don't know how much I will benefit since it is not a monster set-up. Anyone have a recomendation on turbo timer and boost controller?
The rest of the car suspension/brake/tranny wise is done. There are UR Ultra R pulleys on the crank and alt. now, i.e. no power steering or a/c. The rest will get sold AEM/JDM 4-1/Carsound 2.5 and SKUNK2 60mm catback. By the way if anyone want's anyof these they are up for sale.
Yeah that is the only thing I am worried about. According to RC Engineering if my calculations are correct if I am looking at around 350hp and I have 4 injectors with a brake specific fuel consumption of .60 and keeping the max duty cycle @ 80% with just a base fuel setting of 40psi they said 720's would be perfect. At the same time if I run around 48psi pressure they said 660's would work and be a better set-up because the spray pattern would be better coming in at a high pressure still same amount though. I dunno we'll see. Guess that's why I asked for input.
5 Lug
Feb 12, 2018 07:33 AM
