afc hack and no btm
Old Dec 30, 2002 | 11:02 PM
integraracer94's Avatar
Default afc hack and no btm
Are there a lot of people out there running dsm's and afc without btm. If so are you having any problems?
I have a drag III kit with dsm's and s-afc and would like to run about 10lbs(stock internals except block guard)
1. Can I just retard ignition timing slightly with the distributor?
2. How should my correction differemces differ between 6 and 10lbs (low and high boost with profec)
thanks
Old Dec 31, 2002 | 05:07 AM
RAWB's Avatar
Default Re: afc hack and no btm (integraracer94)
I'm running my HACK with timing retarded at the distributor. If I wasn't eventually getting a standalone, I'd get a BTM.
Old Dec 31, 2002 | 09:37 AM
how far retarded are you going on the distributor?
Old Dec 31, 2002 | 10:09 AM
BorderM3's Avatar
Maybe you guys can clear this up for me....
Book says 18BTDC so if i would want to retard it 4 degrees just put my timing light at 14 and set the distributor till the correct niche in the crankshaft lines up with the timing marks?
Old Jun 3, 2004 | 01:06 PM
MooreBoost's Avatar
Default Re: afc hack and no btm (BorderM3)
Bump, wondering the same thing.
Old Jun 3, 2004 | 01:19 PM
drvfast's Avatar
3-4 degress is what most people recommend
Old Jun 3, 2004 | 01:21 PM
USDM 4G VTEC's Avatar
Default Re: afc hack and no btm (drvfast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drvfast &raquo;</TD></TR><TR><TD CLASS="quote">3-4 degress is what most people recommend</TD></TR></TABLE>
exactly
i have the BTM
it stopped working for a day and i was even not considering to go too high without the retard
Old Jun 3, 2004 | 01:25 PM
racinskittle's Avatar
Default Re: afc hack and no btm (USDM 4G VTEC)
I was running a D16z6 w/ 2 degrees retarded on 10psi w/just a vafc set at 35% across for about 4000+ miles. I beat on it quite a bit.
It pulled ****** crazy. But I knew it was gonna be on it's last leg soon (If I didn't eventually do something about the timing sooner or later). So Uberdata it was.....
I'd definately look into it, it's not difficult at all.
Old Jun 3, 2004 | 01:36 PM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BorderM3 &raquo;</TD></TR><TR><TD CLASS="quote">
Book says 18BTDC so if i would want to retard it 4 degrees just put my timing light at 14 and set the distributor till the correct niche in the crankshaft lines up with the timing marks?</TD></TR></TABLE>
I would do it manually. (You're talking about using a digital timing light gun, right?)
Jump the service connector, and make sure the idle is at 750 rpms. (All accessories are off too) Set up the timing light gun and loosen the distributor. Turn it until the GREEN line matches with the pointer on the block side.
Green = 14 degrees BTC
White = 16 degrees BTC
Red = 18 degrees BTC
The lone white line is 0 degrees. Don't set it there.
^That's for B series. The H/F guys have it a little harder. Their timing marks are located on the tranny side, located inside the access hole near the H22/F22 stamp on the block. Same process, just different location.
Old Jun 3, 2004 | 02:02 PM
Joseph Davis's Avatar
*sigh*
https://honda-tech.com/zerothread?id=841443
AFC hack + BTM = the only thing being retarded at a crucial point is your brain.
tobster
Engine Management and Tuning
Aug 20, 2010 05:55 AM
type-GGSR
Dec 26, 2007 09:52 AM
okbubbac
May 28, 2007 05:29 AM
brusk13
Jan 11, 2006 07:01 PM
boost fed ls
Aug 11, 2003 08:26 AM
