degreeing cams with timing light???
Old Dec 1, 2002 | 12:24 PM
b00stedbyFastrax's Avatar
Default degreeing cams with timing light???
in a perfect timed engine with cam gears, pointing a timing light at the gear marks should show them in sync with each other, Right? Now if one were to put a thicker head gasket to drop compression, this would put the cams out of sync with each other (ie intake cam would be advanced) . Is it possible to use the timing light to degree the cams so that they would be in sync instead of a degree wheel? What do you guys think?
Old Dec 1, 2002 | 01:52 PM
earl's Avatar
Default Re: degreeing cams with timing light??? (BoostedbyFastrax)
How do you define perfectly timed? 0 degrees advanced? Wouldn't use lose that perfect timing when you replaced the head gasket? Not sure what you are getting at. Why not just use your cam gear degree markers to correct?
Old Dec 1, 2002 | 02:11 PM
Default Re: degreeing cams with timing light??? (earl)
what i am getting at is that if you take a completely stock engine and put in some adjustable cam gears , start up the motor and point a timing light at both gears, the timing marks on the gears should line up with each other (similar as the crank pulley red mark would be lined up with the pointer on the cover). now if you were to install a thicker hg, the cams would be off depending on the thickness of th HG. so to get back the cams to their original setting, could the timing light be used to set the cam gears (adv/retard) so that they line up with each other?
Old Dec 1, 2002 | 03:24 PM
Jared's Avatar
wont work, your timing light is going to be firing at whatever your advance is, not tdc where the cam gears would line up. If you do have a light that can calculate advance, and set it to whatever your advance is, then sure, your cam gears should line up, unless you've changed something. milling head/block or going witha thinner hgasket advances cam timing, thicker hgasket retards cam timing.
Old Dec 1, 2002 | 06:29 PM
earl's Avatar
Default Re: degreeing cams with timing light??? (Jared)
milling head/block or going with a thinner hgasket advances cam timing, thicker hgasket retards cam timing.
Hey Jared, is there a rule of thumb as to how many thousandths it takes to affect cam timing by one degree?
Old Dec 1, 2002 | 06:46 PM
b18bturbo's Avatar
Earl,
Most blocks/heads are also being decked and usually .0005 or more are usually removed and milled away. But dont we also want to preserve the quench area in the cylinder The area wiht thicker head gasket would increase the quench area for combustion Dont you want the quench area to be sufficient to cool the hot spots and reduce the detonation. I have been told .040 quench area is the way to go.
From what i have seen and built the .046 gasket compared to .076 gasket the the timing goes off approx 2-4 degrees. I would assume that a 2mm gasket would throw timing off about 4 degrees.
What do you think?
[Modified by b18bturbo, 9:47 PM 12/1/2002]
Old Dec 1, 2002 | 09:30 PM
earl's Avatar
Default Re: degreeing cams with timing light??? (b18bturbo)
I'm not sure, Viren but we kind of do what you are saying. Our #1 motor has been decked .020 because of an o-ring problem. We have to use pistons with a custom pin height so as to not stick them out the top of the block. We then use a thicker gasket to bring the head back to stock height. This way timing is not affected but, of course, the compression ratio is lowered slightly.
Old Dec 2, 2002 | 07:23 AM
b18bturbo's Avatar
thats excactly what we do we deck the surface to make sure it true then we use a .046 or .076 depending on the deck height we took off the head and block. Its goo make sure you do that to keep the surface true just my opinion.
coltonbarrier
Feb 17, 2014 07:41 AM
( o )( o )
21
Jul 13, 2006 09:45 PM
ITRfaithful
Oct 28, 2003 09:58 PM
integraracer94
Apr 26, 2003 04:35 PM
b00stedbyFastrax
Mar 17, 2003 06:35 AM
