Is this Correct?
Old Mar 14, 2003 | 03:58 PM
b00stedbyFastrax's Avatar
Default Is this Correct?
Engine fully assembled. Cam sprockets does not line up due to thicker head gasket. checked timing with a timing light at TDC (white mark on pulley), advanced the timing +4, cam sprockets lines up. does this mean that the intake cam was off by 2 degrees? what is a logical explanation?
Old Mar 17, 2003 | 06:35 AM
JimBlake's Avatar
Default Re: Is this Correct? (BoostedbyFastrax)
I don't quite understand what you're saying... You don't use a timing light to check CAM timing. You do that by lining up all the marks with the engine stopped.
After you fix the cam timing first, then look at spark timing. That's what you use the timing light for.
When you just say "timing" we don't know whether you mean cam timing or spark timing.
crfreestyle
Classic Hondas
Dec 21, 2009 02:36 PM
KeithsDAteg
Nov 29, 2009 05:32 PM
