defi gauge question
Old Jan 18, 2009 | 11:06 AM
gosu08's Avatar
Default defi gauge question
this is for those with defi gauges or has experience with them in their R.
im looking to get the defi boost and oil pressure gaugedefi link II control unit?
or can i just hook it up to all the appropriate wires and vac lines?
ive hooked up gauges before but never have had to hook them to a unit prior to other things like website states.
im not sure. it says that i need it but i just want to make sure.
thanks.
Old Jan 18, 2009 | 12:03 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: defi gauge question
if they are defi link gauges, unless they have changed them you need toe defi link controller to make them work.
Old Jan 18, 2009 | 12:05 PM
TubRex's Avatar
Defi gauges are very easy to install. Someone who hasnt installed gauges before can do it!
You will need a control unit to run them. You get a record funtion which is cool.
You will need to splice and solder, but only 4 wires from what i remember from the control unit.. Then all you do is plug in your gauges to the CU and there lit. Then plug in your senders and theyre up and running..
Best gauges by far!! I will be getting some more for the crx..
Go for it mate.. You wont regret them
gosu08
Jan 20, 2009 04:53 PM
gosu08
Jan 18, 2009 04:27 PM
es_squared
Jul 14, 2008 09:36 PM
ninjastance_batmang
Nov 15, 2004 06:16 AM
