Debate: Whether to run the SMC+ or V-AFC for the hack. Help!
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Okay, here's the deal. I've come across two great deals:
1.) SMC+ for $60. (H-T member)
2.) Apexi V-AFC - $100 (deal w/good friend of mine who's car I work on often)
I plan to run DSM 450cc injectors, retard timing 3 degrees and run 9-10 psi w/dyno tuning.
Which one should I buy? It's for a 97 civic EX (SOHC VTEC), greddy kit @ 7 psi currently.
I know the SMC+ is said to be better at preventing CEL's, but the VAFC has a lot more displays and tuning options (i.e. hi/lo throttle).
Suggestions? [/B]BTW, suggestions don't include looking into uberdata, hondata, fmu, filetofit, blah blah blah. I have, and the hack seems to be the best fit for me right now.[/B] Let me know, thanks in advance.
I'd vote for the VAFC if it's only $40 more. The display can offer great insight into what is going on if you know what to look for, plus you can play with VTEC actuation and have Hi/Lo throttle settings. As you have noted, the SMC is better in regards to preventing CEL's because it has internal MAP clamping, but I don't think this should be an issue on a D16 Greddy turbo @7 psi w/ DSM 450's. 9-10 psi will be cutting it closer, just be sure not to exceed the MAP voltage threshold for a CEL, which is ~ 3volts.
I would use the smc. Cheaper and same functionality.
But why on earth wouldn't you consider uberdata? you already have an ecu don't you? A burner is ~$50. Hell, I or anyone else could make you a base map and send it to you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devnull »</TD></TR><TR><TD CLASS="quote">I would use the smc. Cheaper and same functionality.
But why on earth wouldn't you consider uberdata? you already have an ecu don't you? A burner is ~$50. Hell, I or anyone else could make you a base map and send it to you.</TD></TR></TABLE>
I don't want to run uberdata because it is a bit costly for obd-II. P28 - $100, conversion harness - $150, chip burner - $100, chipping - $50 (not doing it myself), dyno tuning - $150...it adds up.
The AFC hack is simple for me and good enough for my goals. Thanks for the suggestion though. Just remember, a complete Uberdata setup is not REALLY free.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe »</TD></TR><TR><TD CLASS="quote">
The AFC hack is simple for me and good enough for my goals. Thanks for the suggestion though. Just remember, a complete Uberdata setup is not REALLY free.</TD></TR></TABLE>
The important stuff is free, plus your prices are a bit bloated.
You do know you have to dyno tune the afc/smc as much as you would with uberdata right? Or run the generic settings which is worse than just running a base map in uberdata.
Get the smc, I was considering it a while back. I would only get the afc if it was the same price.
i ran the SMC+ on my setup for over a year and i was happy with it. and hell, i paid 120 for it brand new and i still thought it was a great value for what it did. i finally upgraded to uberdata though and learned the difference between a hack and real EMS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keebler65 »</TD></TR><TR><TD CLASS="quote">i ran the SMC+ on my setup for over a year and i was happy with it. and hell, i paid 120 for it brand new and i still thought it was a great value for what it did. i finally upgraded to uberdata though and learned the difference between a hack and real EMS</TD></TR></TABLE>
what made you go with Uberdata after a year of using the SMC? what did the SMC lack that Uberdata provided? i am currently running the SMC+ and am just curious. thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civikdude »</TD></TR><TR><TD CLASS="quote">
what made you go with Uberdata after a year of using the SMC? what did the SMC lack that Uberdata provided? i am currently running the SMC+ and am just curious. thanks.</TD></TR></TABLE>
well the main reason was because i wanted a "perfectly flat" A/F line. the smc+ always kept my A/F ratio in a safe range, but i wanted to perfect it. when i changed to uberdata and got a perfect tune, i noticed that some power dips had vanished, which were probably originally caused by the lumpy A/F line. also, being able to move VTEC points, make shiftlights, etc raised my interest as well. to see the difference of A/F that i'm talking about, i have a couple of datalogs that can be found here: http://www.ecimulti.org/uberda...d=352
like i said before, the SMC is great for the price and is terribly easy to install and setup. however, my setup will being seeing more boost soon and i just wanted to feel safe about making the upgrade.
b16booster
Sep 19, 2003 10:45 AM
