sleeves
Old Jan 24, 2008 | 10:33 AM
blakh's Avatar
Default sleeves
ok so i am in need of a set of sleeves and am not sure what to get, i am tight on money so value is key. i can have a local shop put them in for a good price so i just need the sleeves them selfs. i have been looking at JGE sleeves http://jgenginedynamics.com/Sleeves.html
what else should i be looking at? anyone that has used the jge sleeves how have they held?
anyways just give me my options, and remeber that i am on a budget this isnt build your dream motor
Old Jan 24, 2008 | 11:35 AM
Top Ramen's Avatar
Default Re: sleeves (blakh)
First, don't have a shop install them that has not done it many times before, on Honda blocks and has the right equipment. Most machine shops will tell you "sure, we can install sleeves," but there are precious few that can properly install ductile sleeves. If you search at all, you will find several good sleeve companies.
Second, please don't buy anything from that sack of **** Javier. He has ripped off a LOT of people over the years.
Old Jan 24, 2008 | 11:37 AM
DfwBB6's Avatar
JGE isnt known to be a very "reputable" company so keep that in mind when doing business with a shady company
Old Jan 24, 2008 | 12:00 PM
blakh's Avatar
really, i was totally not aware of that. thanks alot for warning me, much appreciated.
so what would you recommend?
and the place i would have put them in is pretty reputable around here for doing good work on hondas, they know there stuff.
Old Jan 24, 2008 | 12:12 PM
blakh's Avatar
heard of LA SLEEVE COMPANY?
found em off of http://www.importbuilders.com/
are they reputable?
Old Jan 24, 2008 | 12:56 PM
Darton's Avatar
Default Re: (blakh)
Since you are in Vancouver take your block to Portland Engine Rebuilders in Portland, Or. (503) 230-1276. They can help you out with sleeving your block and they know what they are doing. They can supply you with sleeves and installation.
Old Jan 24, 2008 | 01:00 PM
blakh's Avatar
alright, thanks.
will give them a call right now!
Old Jan 24, 2008 | 01:15 PM
Schister66's Avatar
Man U FTW
There are a number of reputable sleeving companies in the Marketplace. Personally i would go with Benson, Darton or Golden Eagle. Spend the money to get it done right rather than risking your build on a half-assed sleeving job
Old Jan 24, 2008 | 01:23 PM
Darton's Avatar
Default Re: (Schister66)
I wouldnt recommend a shop that didnt know what they are doing. They have been installing Darton Sleeves for about 8 years now. They know what they are doing.
Old Jan 24, 2008 | 01:46 PM
Schister66's Avatar
Man U FTW
Default Re: (Darton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darton &raquo;</TD></TR><TR><TD CLASS="quote">I wouldnt recommend a shop that didnt know what they are doing. They have been installing Darton Sleeves for about 8 years now. They know what they are doing.</TD></TR></TABLE>
Thats good...i just think its a good idea to look around before doing anything. I've heard more than my fair share of sleeving horror stories
Old Jan 24, 2008 | 02:52 PM
CerealKiller's Avatar
Default Re: (blakh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blakh &raquo;</TD></TR><TR><TD CLASS="quote">heard of LA SLEEVE COMPANY?
are they reputable?</TD></TR></TABLE>
OH, man. First JGE than IB, your going the opposite direction. If your looking for just a set of sleeves, go with Darton. if you want a whole sleeve install, go with Golden Eagle Mfg. you can't go wrong. good luck with your search.
*let's not start ANOTHER "who's sleeves are better" thread.
Old Jan 24, 2008 | 04:02 PM
blakh's Avatar
lol thanks cereal, i was looking through some other sleeve threads and some guy mentioned ib cause they did eagle sleeves or something, so i thought i would ask.
but i have talked to the guys at PER and i think i will be going with them even though it is a little more then i wanted to spend i think after i figure in shipping costs it is almost the same to send it off so ill just stick with them.
Old Jan 24, 2008 | 09:14 PM
Top Ramen's Avatar
Default Re: (blakh)
It really is best to play it safe when getting sleeves. I have seen so many people who have ended up with small coolant leaks or have had the sleeves drop. Its a real nightmare to go through all of the work and money to build a motor, then have to tear it down again a month later.
Best of luck with your project.
cvelazquez
Jun 17, 2014 12:36 PM
Woody.
Feb 26, 2011 06:25 AM
turbob18a1
Jun 23, 2003 07:57 PM
631 Teggy
Feb 9, 2003 07:56 AM
EEK
Aug 9, 2002 09:59 AM
