Daily driver Tire setup question
Old 07-10-2008, 12:05 PM
accord99power's Avatar
Default Daily driver Tire setup question
for the hp/tq listed in my specs, what tires are you guys running fgor a daily driver and if you want the most traction without going to slicks? anyone know how wide of a tire i can go on stock suspension forget the rim size for this ?
Old 07-10-2008, 05:28 PM
inspyral's Avatar
If it's a daily driver and you don't ever plan on having to drive on snow, I would go with a nice set of summer tires. Obviously your best option for traction without running slicks would be a drag radial, but those aren't going to last very long daily driven. I think a good set of summer tires would be an ok compromise between longevity and street traction. Maybe look into something like an Azenis or other "ultra high performance" summer tire. Whatever you do, stay away from "touring" and "all-season" tires.
Old 07-10-2008, 05:30 PM
GSROWNSU's Avatar
I'm running Falken Azenis and i LOVE THEM!!! They will only last about 12,000 miles or so but they grip really well. Plus driving on them they feel like normal tires...no road noise or vibration. I'm making 313whp 227wtq on 10psi and i have all of 2nd gear. Size is 205/50/R15
Old 07-10-2008, 07:14 PM
Man U FTW
Schister66's Avatar
I currently daily a set of BFG KDW2 drag radials, but i used to run Falken Ziex 512s. If i had to get a street tire, my only choice would be a set of Falken Azeni RT615s.
Old 07-11-2008, 08:42 AM
Bjorn20's Avatar
Default Re: Daily driver Tire setup question (accord99power)
well if you want the most traction (in dry pavement im assuming) for a daily, i would go with any "extreme performance" tire in tirerack. The downside is most of them dont have very long tread life and horrible in rain.
I'm personally going to be getting some goodyear f1 gs-d3's for the simple reason that i can sacrafice a little dry performance for wet conditions.
but this should really be in the tire/wheel forum
Old 07-11-2008, 11:08 AM
Scheizty's Avatar
Azeni RT-615
Old 07-11-2008, 11:24 AM
chimmike's Avatar
Default Re: Daily driver Tire setup question (Scheizty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scheizty &raquo;</TD></TR><TR><TD CLASS="quote">Azeni RT-615</TD></TR></TABLE>
+1. Or, BFG t/a KDW2. Those tires are badarse.
Old 07-11-2008, 01:41 PM
Default Re: Daily driver Tire setup question (chimmike)
thats what i was looking for thanks guys! i think the widest i can go is 225 on my 99 accord true or no?
Old 07-11-2008, 04:50 PM
rmcdaniels's Avatar
I've DD'd Toyo RA-1's. They are R-compounds, but they work well on the street and last for a bit. 10x better than the RT-615's that I used to drive.
Old 07-11-2008, 05:00 PM
welfarepc's Avatar
Default Re: Daily driver Tire setup question (rmcdaniels)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels &raquo;</TD></TR><TR><TD CLASS="quote">I've DD'd Toyo RA-1's. They are R-compounds, but they work well on the street and last for a bit. 10x better than the RT-615's that I used to drive. </TD></TR></TABLE>
r-comp for the win
Old 07-14-2008, 01:34 PM
Scheizty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chimmike &raquo;</TD></TR><TR><TD CLASS="quote">
+1. Or, BFG t/a KDW2. Those tires are badarse. </TD></TR></TABLE>
+2
Old 07-14-2008, 07:00 PM
Man U FTW
Schister66's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chimmike &raquo;</TD></TR><TR><TD CLASS="quote"> BFG t/a KDW2. Those tires are badarse. </TD></TR></TABLE>
They are great and they also look great with the right rim offset. I love how mine stick out past the fender just enough.
Old 07-15-2008, 09:58 AM
boostincoupe's Avatar
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: Daily driver Tire setup question (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">
I miss my old drag radials.
I currently rock a pair of 225/45/17 BFG G-Force drag radials...
s2000tracknut
05-22-2017 02:29 AM
pooleegt1991
05-18-2010 11:00 AM
EGJDM
04-04-2007 11:28 AM
TunerN00b
10-15-2005 09:44 PM
str8cyko
13
10-18-2004 11:12 AM
Quick Reply: Daily driver Tire setup question
