d16 turbo. need help plz
ok so i got a d16 turbo civic. i was wondering if anyone could give me a good idea on how to hook up my boost controller and fmu into the vacum source. my car runs decent untill it gets to about 7lbs and up of boost and im into it. it seems like its starving for. does any one have any recommendations as to wut i should to and how to hook my boost gauge up so i can control it. any info would be great. thanks
ive had it hooked up like this immage on the website and it dont work for soem reason? http://cgi.ebay.com/ebaymotors/MANUA...item3a52ccc2b4
i just need to know how to hook up my boost controller. cause no matter wut ive tried it still keeps makin as much boost as it wants. so any info would be great or a digram 2, or website plz. thanks
just to clarify. is your car tuned?
and just throwing this out there, you can nbot set a boost controller lower thenb the spring that is in the wastegate (some e boost controllers can do this).
Meaning if you wastegate spring is a 7psi then you can only go higher.
SloB16crxMike
Aug 15, 2006 10:31 AM
