BOOSt CONTROLLERS
Old Oct 3, 2003 | 09:05 PM
HotRodTeg's Avatar
Default BOOSt CONTROLLERS
I was wondering for the high horsepower guys(600+)
What kind of boost controllers are you guys running?
And have you ever tryed the innnovative MSBC?
thanks for help
Old Oct 3, 2003 | 09:06 PM
DaveF's Avatar
Default Re: BOOSt CONTROLLERS (streetracer)
great double post...
grasshopper.
Old Oct 3, 2003 | 09:11 PM
HotRodTeg's Avatar
Default Re: BOOSt CONTROLLERS (2.2Lcivic)
sorry i just wanted to know
Old Oct 3, 2003 | 09:16 PM
Captn. Save A Hoe's Avatar
the WORLD ELECTRONICS one... =D...id give my kidney's for one of those...
oh yea plus a turbo to use that with
Old Oct 3, 2003 | 09:26 PM
HotRodTeg's Avatar
Default Re: BOOSt CONTROLLERS (The P.I.M.P)
The world racing one? wow that **** is spendy
whats the differance with that one and the innovative?
Old Oct 4, 2003 | 06:19 AM
Gravy's Avatar
about 500 bucks and you can boost like 100psi.
Old Oct 4, 2003 | 06:55 AM
HotRodTeg's Avatar
Default Re: BOOSt CONTROLLERS (Gravy)
hey gravy is that the one you are using?
Old Oct 4, 2003 | 07:43 AM
HotRodTeg's Avatar
Has anyone tryed the blitz sbc-id
It saids that it has 4 programmable boost levels controller.
does that mean that it is a gear based boost controller?
like and i get 10psi in1st and like 15 in 2nd?
Old Oct 4, 2003 | 01:42 PM
saso
Guest
Posts: n/a
I would go with the innovative, it does what the eworld but is cheaper.
Old Oct 4, 2003 | 01:47 PM
HotRodTeg's Avatar
Default Re: BOOSt CONTROLLERS (saso)
We haev the innovative in the car right now and it is being a pain in the ***.
It spikes boost like 6-8 psi and it cannot hold boost.
we gonna give them a call monday morning and see whast going on.
Have you used the innovative SASO?
Old Oct 4, 2003 | 02:29 PM
saso
Guest
Posts: n/a
Default Re: BOOSt CONTROLLERS (CrazyCompression)
no i havent but i dont mind a little spike..depends. Every application is different. Now about holding boost thats another story, whty wont it hold boost , does it drop off.
Old Oct 4, 2003 | 04:49 PM
jarel's Avatar
I dunno if this would help...but I have the Blitz SBC-ID on my WRX and there are 4 programmable channels, for each one you do the set/gain settings. Basically you set it to reach a certain amount of boost on whatever gear you want (final gear that you'll end up in)
(ex: Set: 56, Gain: 20; yields me to 16lbs in 4th gear. So for 1st gear, its around 13.7lbs,
2nd - 14.5lbs,
3rd - 15.5lbs,
4th - 16lbs)
It isn't like the Apex where you can set it for each gear and rpm.
Hope that helps some.
Old Oct 4, 2003 | 06:47 PM
HotRodTeg's Avatar
Default Re: BOOSt CONTROLLERS (chyknees)
oh ic so your asying its not like a gear based boost controller?
so you set you final gear boost and it will get there at the end of track?
But if it those that then how does it know your going to be in 4th gear?
or is there like a speed senor wire you tap into?
Old Oct 4, 2003 | 11:19 PM
jarel's Avatar
For me (wrx), there are just the hoses going from the actuator/wg and turbo to the solenoid. The way i figure is that you set the max boost level that you want and play around with it until you get the right amount of boost in the final gear. I'm not sure if that seems odd...but i can't really put into words that I mean. Sorry if your confused.
http://www.scoobymods.com/foru...=1890
Thats a link showing the pdf file of the manual of the SBC-ID
Under the Boost section....it explains it a bit more clearly on how to set it up.
hope that helps
TypeSLO
May 29, 2007 05:12 AM
ATS*Mark
Feb 18, 2004 01:25 PM
