d15b vtec engine
Old May 11, 2005 | 12:22 AM
jdjustme's Avatar
Default d15b vtec engine
I have a problem with my rps, they are jumping up and down in between
900-1,500 rps when i come to a full stop. the only modification that i did was a
OBX performance cam (for turbo), and a Y8 manifold, and the Y8 fuel rail. I try retarding the timing and advancing it. but is the same thing I check all the vaccum hoses and idle mixture connection and adjustments but is the same
so i have no clue, please help...
Old May 11, 2005 | 03:31 AM
Tad's Avatar
Tad
when you put that Y8 manifold on did you reuse the gasket?
soundsl ike a vacuum leak to me,
and considering you swapped intake manis that would make perfect sense.
get a new gasket on there, and make sure theres no old gasket stuck on, and that you didnt scratch it badly scraping the old one off.
Old May 11, 2005 | 10:49 AM
CRXVTEC69's Avatar
Default Re: d15b vtec engine (jdjustme)
TPS sensor - replace it
AllmotorGSReg
20
Apr 12, 2013 05:57 PM
Cheefer_EX
Nov 17, 2012 04:28 PM
MildWater
21
Mar 7, 2007 12:27 AM
mr. carpenter
Apr 20, 2005 07:28 PM
foesicks
Dec 5, 2002 10:35 AM
