d15b forged build
Hey everyone! I have a turbo d15b non vtec with built head but stock block... My questions were was what forged pistons, rods, amd sleves should I use, because im having a hard time finding ANYTHING on the d15b since they are not used as turbo builds often. I heard the crankshafts in the motor should be bullet proof. Is that correct? Im running 18psi at the moment and im awaire i will blow the block soon.. P.S i dont want to hear about how i should swap to a b.. That is not really in the qestion right now.. Thank yall
Crank is fine, Its been ahwile since i played with D series pretty sure it had different rods, just checked eagle rod listing and did not specify it will work with d15, maybe check with go autoworks? he knows D series pretty well.
stock sleeves Im not sure of but im sure there less then b series so maybe good till about 250.
whats your power goal
You can find a complete swap on H motors for about the same as sleeving and rebuilding the D series
Ohh by the way u might try driving a 300-400 hp honda......recently got tuned on 400hp its by far the fastest car ive ever owned or driven. 4th/5th at this power level scares me I wouldn't want any more, at least on the top end I do like the mid range power tho
Of all the D15 build stuff I have searched for, there is a lot of info. BUT, a lot of it involves started projects that never finished. Few built, even fewer stock. Most of the newest info was from around 2014 but those projects never saw through. Now that being said...
Failed D15 builds that I managed to find seem to have destructed due to breaking bearing cap bolts.
Everyones Hero
Mar 22, 2006 06:37 AM
Bakeoff
Feb 1, 2004 07:11 PM
