turbo set-up help...
Old Jun 1, 2009 | 06:38 PM
jdmpoweredsol419's Avatar
Icon2 turbo set-up help...
im building a d16z6 turbo..and i was wondering what turbo set up would be best to hit 400hp. my block is goin to be built w/ vitara pistons, scat rods, acl bearings 75.5 mm bore, crank, rods, pistons balanced, crank knive edged, arp headstuds, and stock head for right now. i was also wondering if i had to notch my block cuz of my rods.
Old Jun 2, 2009 | 05:34 AM
95civhb's Avatar
Default Re: turbo set-up help...
I'm not 100% on the scat rods, but as far as i know most aftermarket d series rods require the block to be notched....
400hp could be hit with a lot of different turbos.. Here's a good reference..
http://www.turbod16.com/viewtopic.php?f=3&t=4140
look around at other builds too... some turbos will have more lag than others... obviously you have to decide if you want quicker spool/more high end power, etc...
92lxsleeper
Jan 22, 2011 11:44 AM
001020
Mar 20, 2005 06:51 PM
mtlmotorsport
Feb 13, 2005 07:09 AM
Turboed ED7
14
May 27, 2004 04:55 PM
