Cylinder to Piston clearance
Old Jan 25, 2003 | 02:18 PM
crxhybrid1320's Avatar
Default Cylinder to Piston clearance
What clearences are recommended for 9.1 compression in a B18c.
Running the JE pistons!
Could the piston to cylinder clearance be the problem with the smoke or will this just couse piston slap?
Read my Smoking poll have problems with smoking also, let me know what you think.
Old Jan 26, 2003 | 06:32 AM
Default Re: Cylinder to Piston clearance (crxhybrid1320)
Anyone know their clearances!
Old Jan 26, 2003 | 09:15 AM
highbrid's Avatar
my clearance was set to .0035"
Old Jan 26, 2003 | 09:47 AM
CRVRX's Avatar
Default Re: Cylinder to Piston clearance (highbrid)
Every piston has a different clearance.
On a 81mm bore , Wisco say .0026-.0028
Check with JE. And make sure your machine shop has the ability to measure in 1/10 of thousands.
Old Jan 26, 2003 | 06:27 PM
Default Re: Cylinder to Piston clearance (CRVRX)
Will this cause smoke or piston slap or both.
Engine is not that noisey but burns oil.
I guess I need to contact JE.
Old Jan 26, 2003 | 08:01 PM
lazerus's Avatar
contact ONLY JE If your clearances are too tight, then you will find out the very hard way...
Old Jan 26, 2003 | 08:07 PM
TREVER's Avatar
If I remember right JE fi pistons were .0032 to .0040 depending on appl. yes smoke and slap will result from to much clearance.
Also I run .0032 for Wiseco fi pistons I think there spec is for n/a and they don't account for the expansion/heat a fi motor sees.
Old Jan 26, 2003 | 08:29 PM
earl's Avatar
What is your clearance at now?
Old Jan 27, 2003 | 04:08 PM
Default Re: Cylinder to Piston clearance (earl)
Do not remember and did not write it down.
Contacted JE today they said it should be at .003
and no more than .004. Need to remove the head and see.
JE also told me that the top ring is chrome and the cylinders needed to be honed for that chrome ring.
What do you use to filefit your rings. I used a ordinary file but wanted to know if I should buy the tool to make sure its squared evenly..
Old Jan 27, 2003 | 06:04 PM
earl's Avatar
Lock the file in a vice, fill the gap with the file and pull the ring forward only. By holding the ring against the file, your gaps should remain straight.
Old Jan 27, 2003 | 06:20 PM
Wont the back edge have a burr on it then.
file it off carefully then.
Thanks
Jason
Old Jan 27, 2003 | 09:16 PM
earl's Avatar
You must deburr ALL edges. This is very important. You will scratch the cylinder walls and the ring will not seat properly in the ring land.
Old Jan 29, 2003 | 05:36 PM
When you say deburr the edges just make sure the edge of the ring is smooth and does not have any rough edges and spins freely on the ringland also
Correct!
Old Jan 29, 2003 | 07:02 PM
RacerStev's Avatar
Default Re: Cylinder to Piston clearance (lazerus)
Piston to wall really depends alot on just how much power you are gonna make.
I've seen Je's go from .0035 to .0065.
Steve
90 Geo Storm Turbo (10.0's at 140)
95 Neon-Sport FWD (will be faster..)
Old Jan 30, 2003 | 03:27 PM
Default Re: Cylinder to Piston clearance (RacerStev)
Thanks
I dont want too much slap so im doing it between .003"-.004"
Old Feb 1, 2003 | 04:22 PM
b19coupe's Avatar
Ring filing is a pain in the butt, but since I have to do it everytime I build a motor, I spent $85 for the ring filing tool from Manley.
Old Feb 2, 2003 | 12:50 PM
Default Re: Cylinder to Piston clearance (b19coupe)
was it worth it the money
i think mine are not square and causing oil consuption
Ep3tat98
K Series
Feb 3, 2016 10:20 PM
lude98SH
Dec 20, 2007 05:05 AM
EJ8 GSR-T
Nov 21, 2006 05:16 PM
ludelvr
Nov 26, 2003 03:56 PM
B20LS-T
May 13, 2003 04:17 PM
