cylinder bracing/stabilizers
Old Mar 10, 2003 | 01:06 PM
ill_take_one's Avatar
Default cylinder bracing/stabilizers
Guys, I'm so fricken lost now.
I've been debating whether i should build my block up for the t3/t04e turbo i'll be slapping on. I've already got the pistons/rods.
Anyway, i see that there is a low price on this board for Darton sleeves. I figure i might as well get the 75mm darton sleeves, so i can use the free pistons i got from someone. (i figure that my stock cylinders will have to be bore out, so these pistons i have wouldnt work)
I call up this machine shop that has worked on plenty of hondas/acuras. He thought the Darton sleeves were an overkill for what i want. I want a good 250-300hp on my D16z6 engine somewhat reliably. Keep in mind this is going to be street driven, track once and awhile.
Anyway, he goes on to say, "well i could save you some money". Rather than blowing it all on the darton sleeves plus ($1000 install! ), we could brace/use stabilizers to let you boost up to around 20 psi!? He also said they could put in sleeves that arent closed deck for around $400. He thought that the closed deck dartons arent going to be good for the street, because of cooling issues.
Can anyone on here tell me what the stabilizers are all about? and if they are worth it?
Keep in mind, this place has built MANY street/NHRA/Sprint car engines...and some import engines as well...They know their ****..
What the hell should i do?
Thanks
Old Mar 10, 2003 | 07:33 PM
Default Re: cylinder bracing/stabilizers (ill_take_one)
Please...help!!
Any thoughts/opinions?!?
Old Mar 10, 2003 | 07:58 PM
Westsideboy's Avatar
I remember reading about block guards in magazines. I forget who makes 'em though...(sorry brain fart)
Old Mar 10, 2003 | 08:03 PM
Tinker219's Avatar
Please...help!!
sounds like they are doing "block posting". I know Tom Payn @ PaynTech was doing this for awhile, with great success. Thats about the extent of my knowledge. on ya, same concept as blockguard, but without the heating/cooling issues....
Old Mar 11, 2003 | 05:44 AM
Default Re: cylinder bracing/stabilizers (Tinker219)
Please...help!!
Yeah, posting is the same thing. I just couldnt think of the terminology people have been using on here. He just said something about using stabilizers.
Well maybe i'll have to go with that instead then.
any other thoughts?
Old Mar 11, 2003 | 06:22 AM
baddassduramax's Avatar
i have a race engineering block gaurd on my LS and no cooling problems here, maybe you could post ur block and put a block gaurd on too
LS-turboner
Dec 31, 2009 01:13 PM
flatblackintegragsr
Feb 24, 2008 10:52 AM
alex_s817
Apr 17, 2007 12:31 PM
Servo
Apr 13, 2005 01:35 PM
Cyber ITR
Apr 24, 2002 06:41 PM
