Cutting Radiator Fan Shroud for Turbo
Turns out my Stock Fan won't fit because the Compressor housing rubs up against it. I've seen a couple people cut the shroud, and a little bit of the fan-- but I'm looking for a couple of suggestions. Is this okay? Reliable? Will i get any heat problems?? Anyone have any pics?
HT's Biggest Loser
Re: Cutting Radiator Fan Shroud for Turbo (integranator)
I cut the shroud on my old fan, and it worked fine, just have to make sure you cut it, so wwhen the fan is on, nothin hits, I eventualy got a slimline fan, see pics below
I did that. My fan and car run fine. The fan is a little louder now since I trimmed the blades.
Re: (Kutsuju_SLeePER)
i cut my shroud and fan to pieces.. i just ordered a slim fan.. cutting it made a lot of vibration and i dont think the cooling was as fast.. took a while.. especially since i only had one fan because fluidyn didn't allow two..
New User
Or you could get a pusher fan that mounts in front of your radiator... do a search for pusher... i remember seeing a good post with pictures... runs like 70 buck at autozone, kragen, pepboys places...
Just another option
Just another option
Re: (Civtek)
Can u mount the Pusher on the Stock Radiator no problem. So do u get a Pusher and a PULLER?
and put them both on the other side of the Radiator
i never really took a pic of the fan but i might have a pic of the engine bay where you can see the clearance.let me take a look.nope,i dont have one,and no digi to take a quick pic.they look exactly like the one in the top of this post.
