Custom turbos-problems?
Old Apr 10, 2002 | 08:48 AM
  #26
pornstarSR's Avatar
Default Re: Custom turbos-problems? (int3gra)
umm theres to ways of thiking,
1 is internal wastegate is less accurate and not as High Performance, and your potential power is limited
2 they look kind of gay, and the way the wastegate works is it dumps right near the exhaust outlet of the turbo so you kind of have this lumpy downpip thing, unless you custom build a good one.
to be truthful, which maybe a mistake on this board....i have a HKS gt2510 ball bearing turbo about to be install on our race car, the turbo is 63 trim on the compressor wheel, .60 A/R and 62 trim on turbine wheel, but guess what......it has an internal wastegate, the turbo is rated to produce 300 hp on its own.....so thats good enough.....but when i first was talking to hks about it i said, is there any way to convert it to external...i looks kind of gay, they laughed and said well you can, but just see how it works before you do anything, you should be happy with it......so im waiting to see
my sugestion is that you should find a turbo that will work for your setup, and find a manifold for your setup, if its and internal wastegate with and external wastegate manifold it will be kind of gay, and if its vice versa it will not be good at all(motor go boom)
Old Apr 10, 2002 | 08:51 AM
  #27
TurboSedan's Avatar
New User
Default Re: Custom turbos-problems? (pornstarSR)
My custom setup is here:
http://www.geocities.com/nightstalke...ture_mods.html
Old Apr 10, 2002 | 08:52 AM
  #28
pornstarSR's Avatar
Default Re: Custom turbos-problems? (falconGSR)
the way its mostly done is the size of oil line coming into the turbo, to big and it floods the turbo and blows through the seals, to small and it doesnt lubricate enough........find out what size is used for that specific turbo and at what pressure and try to match it as close as posible
Old Apr 10, 2002 | 08:53 AM
  #29
int3gra's Avatar
i was thinking of jumping on the inlinepro groupbuy..........but i dont have a turbo yet.......... should i get the turbo first and then the manifold?
Old Apr 10, 2002 | 09:01 AM
  #30
pornstarSR's Avatar
well it all comes down to what kind of turbo it is weither or not it has a internal or external type wastegate.....but i know either on here or thepartstrader.com you can find and external type turbo pretty easily
Old Apr 10, 2002 | 09:04 AM
  #31
int3gra's Avatar
oh ok, i get ya
Old Apr 10, 2002 | 09:09 AM
  #32
bruthaboost's Avatar
Needle valve maybe?
Old Apr 10, 2002 | 07:36 PM
  #33
Scylla's Avatar
Default Re: Custom turbos-problems? (b18bpwr)
Thanks for all the info. I think I am gonna go custom. Here is what I have planned on getting:
1. Turbocharger
2. Turbo Manifold
3. Downpipe
4. Charge Pipes
5. Oil Feed/Return Line
6. Fuel Management Unit
7. Wastegate
8. MAP Sensor By-Pass Valve
9. Various hoses/pipes (silicone, etc.)
And others:
10. Blow-Off Valve
11. Intercooler
12. Gauges (Boost, A/F, and EGT)
13. Better fuel pump and injectors
14. Apex SAFC
15. Thermal 3" Exhaust
If anyone can recomend their favorite brands, that would help
Old Apr 10, 2002 | 09:00 PM
  #34
93LSivic's Avatar
Default Re: Custom turbos-problems? (Scylla)
1. Turbocharger
2. Turbo Manifold
3. Downpipe
4. Charge Pipes
7. Wastegate
And others:
10. Blow-Off Valve
11. Intercooler
14. Apex SAFC
Well, theres nothing too custom about what you have there.
You will definetly need 1 through 14 if you want any kind of a turbo system??
Whats so custom about that?? Buy a DRAG and be done with it....
Custom would be some crazy turbo, an equal lenght manifold, a 40+mm wg, 3: dp cat and exhaust, standalone, injectors, blah blah blah.....
Basically you dont want custom, you want a kit that Ben can easily assemble for you!
Old Apr 10, 2002 | 09:41 PM
  #35
int3gra's Avatar
Default Re: Custom turbos-problems? (93LSivic)
he said he wanted to do it slowly over the summer.
Old Apr 11, 2002 | 08:13 AM
  #36
Scylla's Avatar
I have certain brands in mind for 1-14, I was simply asking if those are the necessary parts to piece a turbo kit together.
Old Apr 11, 2002 | 10:41 AM
  #37
cyan1de's Avatar
a properly built custom setup will be more reliable and higher quality than any turbo kit out there on the market. however, the price will probably be higher, but you gotta pay to play. i would also recommend a standalone engine management COUGH*hondata*COUGH instead of the alphabet soup setup. standalone = reliable
Old Apr 11, 2002 | 11:03 AM
  #38
TurboSedan's Avatar
New User
Default Re: Custom turbos-problems? (cyan1de)
The jewel of my custom setup is the Hondata 2B. After doing some research, I wanted to save myself the hassle of going from the FMU/inline pump setup to Hondata. More money spent now=less money spent later.
Old Apr 11, 2002 | 05:56 PM
  #39
Scylla's Avatar
Default Re: Custom turbos-problems? (97CivicFerio)
Thanks for all the help, guys...I'll look into Hondata, but I don't know if my wallet can withstand it, hehe
Prelude Vtec 23
Apr 23, 2003 04:22 AM
v-attack
Apr 10, 2003 04:12 PM
falcongsr
Jan 24, 2003 12:35 PM
DannyITR
Oct 26, 2002 11:41 PM
coupedup
May 8, 2002 09:59 PM
