Custom Kit?
Old Jun 9, 2005 | 08:39 PM
97exd16's Avatar
Default Custom Kit?
how does this sound? for my new custom turbo kit for my 1997 Honda Civic Ex with a D16Y8?????? wut are the specs on the turbo and with a stock d16, about how much hp will i make? and is the install farely easy or difficult?
T3/T04E 60 trim
.63A/R
External 35mm wastegate
Spearco 23x6x3 intercooler
TurboXS Type H-RFL BOV
with custom piping?
and to you moderators!!! dont delet this one please and dont lock it cause all i want is some info and you've already deleted one of my threads and you locked one after 3 posts back to me please dont delete it!!!!!!!!!
Old Jun 9, 2005 | 10:05 PM
2000psi's Avatar
From: We Cant Stop Here This Is Bat Country, So CaL, USDM
Default Re: Custom Kit? (97exd16)
Sounds good, you need something to hang that turbo from now and some engine management and the oil feed/return lines. I would go with a thinner and longer Intercooler core. You really don't want to go over 180whp since this is your first setup. GET IT TUNED ON A DYNO!!!
Old Jun 10, 2005 | 07:09 AM
97exd16's Avatar
Default Re: Custom Kit? (2000psi)
anybody else???? help me out with specs cause 2000psi said i shouldnt go over 180 and i'd like to hit at least 220 but is the turbo capable and will it not blow up my little D16?????
Old Jun 10, 2005 | 09:09 PM
97exd16's Avatar
anyone?
Old Jun 13, 2005 | 06:42 PM
97exd16's Avatar
wtf anybody got stats? numbers?? anything???
Old Jun 13, 2005 | 06:58 PM
1995Ex_Sedan's Avatar
Stats? Numbers?
Dude, Every single car is different. I could have the same EXACT car as you with all the same parts and tuning, And yours could run better. Its an HMT setup it sounds like your building. There are no "Numbers" That you can just automatically get. You need to put the kit together, get tuned, fiddle with the ratios, the fuel, etc. Your post or thread probably got deleted because "How Much will I make" Topics are usually not allowed, or frowned upon. Read the rules again. Do some research. I'm still in the process of getting my turbo parts and I started 3 months ago. Take your time and do it right.
Check out http://www.homemadeturbo.com , There you will find a plethera of useful information.
MurtazaDSM
Aug 9, 2009 11:32 AM
JdmH22Acorn
Nov 16, 2005 07:52 AM
hotaccord243
Dec 11, 2004 08:08 AM
mwasnp
Feb 16, 2003 08:03 PM
djmano
Jun 20, 2002 04:26 PM
