Crower 403s for turbo application?
Old Sep 25, 2013 | 04:59 PM
TravisBiggie's Avatar
Default Crower 403s for turbo application?
Yes, I searched for over 30 minutes going through threads and didn't find what I'm looking for.
Ive read about 404s with turbos, but nothing about 403s
81mm npr coated pistons
eagle rods
60 trim turbo (pte 6031e)
1000cc injectors
walbro 255
stock fuel lines/rail
b18b1 head completely stock.
springs/retainers purchased, debating cams.
Possibly a mild port and polish job?
Currently putting down 362whp on a stock head with 19.5psi. I'm hoping for ~450whp with my set up and a little more boost.
Thoughts? Thanks
Old Sep 25, 2013 | 05:20 PM
Natural Aspirations's Avatar
Default Re: Crower 403s for turbo application?
IMHO the turbo is probably the weakest link in your setup. 60-1's are not the most efficient turbos for our applications, a smaller billet compressor wheel will wake up your engine and still be large enough to reach your goal.
AKA 5831
Not that is a direct comparison I have used the 403's on a supercharged B20 and did have positive results.
Old Sep 25, 2013 | 05:26 PM
6031 vs 5831
The 5831 is running 2 PSI more, at similar boost pressure the 5831 made similar numbers with much better response.
Old Sep 25, 2013 | 06:31 PM
turbo definitely a limiting factory, but I prefer not to change it its since quite new.
Any ballpark guesses on how much power I can get out of this setup with the crowers? (stock TB and intake manifold)
Old Sep 26, 2013 | 01:55 AM
It's not a limiting factor, it's just not appropriate.
No one can guess your HP. Do it and report back.
Old Sep 26, 2013 | 04:15 AM
LightningTeg's Avatar
Community Builder
Go digging through the almost 2000 page thread on LST setups. There are plenty of people running 403s
Old Sep 26, 2013 | 04:33 AM
bigG's Avatar
And people with non vtec and stock ports making 600whp^^^^ lol truly is a awesome setup
Old Sep 26, 2013 | 05:43 AM
Turbo-LS's Avatar
The 403's work well with boost and for thr turbo you have should work fine and wake the motor up more up top and a little mid range.
ArniFPR
Jun 20, 2014 07:01 AM
yungkhmer
Apr 5, 2012 08:45 PM
ef9civicgen4
Jan 11, 2008 01:45 PM
.:si:.
Dec 4, 2007 11:53 AM
djtrini
Jan 17, 2007 11:52 AM
