crome???
Old Feb 2, 2006 | 09:25 PM
sycamore
Guest
Posts: n/a
Default crome???
so i just down loaded crome and i was going throught the maps and i very counfsed. i have been doing tons of reading on pgmfi.org and i still dont under stand. could some one give me a break down of who to tune with crome how i can change my map.. do i have to buy crome pro do do that or whats up
and where can i find more base maps
to thoes of you who are helping me thanks.. and i dont really know what im talking about so please keep all negative comments to you slef.
Modified by sycamore at 12:24 AM 2/3/2006
Old Feb 2, 2006 | 09:32 PM
SiAutoX's Avatar
Default Re: crome??? (sycamore)
I can give all info I have with useing crome.....My tuner used crome to tune my car and said i needed crome pro if i wanted to hook my laptop up to my ECU....so if thats whats your asking then yes you need pro. If that didnt help then use this as a BUMP
Old Feb 2, 2006 | 10:02 PM
sycamore
Guest
Posts: n/a
Default Re: crome??? (EF'n Turbo)
yes and no.. but i found out some more about what i was looking for and some more question
how i change my map
where are all the base maps im useing a ls with 440 and stock fule pump for now getting one on next pay check.. but any help is needed
Old Feb 2, 2006 | 11:24 PM
sycamore
Guest
Posts: n/a
ttt any one
Old Feb 3, 2006 | 01:16 AM
Tinus Tussengas's Avatar
You really don't need crome pro. You just need a good wideband lambda, for datalogging on your laptop. You need the rpm, a/f and map signal. When a/f is to low, let the injection time in your crome map increase. for that rpm, and map value. Your datalog program has nothing to do with crome. Datalogging is for reading your a/f, and then with crome you correct it.
When corrected you have to program a new chip, start the engine, en datalog again, and see if your a/f is getting better. Repeat this till your a/f is right. This is all possible with crome free. You even can use rtp (real time programming) with crome free. Then you'll use a romulator, whitch connects your pc with your ecu, so you don't need to program a new eprom every time.
Crome pro has a datalog function, so datalogging is in crome, and crome wil autocorrect your a/f, by reading map, a/f and rpm. That goes a lot faster, but it isn't necessary. Good luck!
Old Feb 3, 2006 | 04:50 AM
93turbo16's Avatar
On cromes website. http://www.tunewithcrome.com
There is a walk through video it shows you EXACTLY what to do and a guy is talking to you while he is doing it.
DL is an watch it, best advice.
Old Feb 3, 2006 | 07:11 AM
sycamore
Guest
Posts: n/a
thanks a ton for the replys i found out tons of info last night.. very both of you guys were very helpfull
Default Re: (93turbo16)
that walk-trough is only about crome pro..
Old Feb 3, 2006 | 07:30 AM
93turbo16's Avatar
Default Re: (Tinus Tussengas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinus Tussengas &raquo;</TD></TR><TR><TD CLASS="quote">that walk-trough is only about crome pro.. </TD></TR></TABLE>
There are more than 1 demo and what not. It still shows you what is going on.
i.
Feb 12, 2009 11:50 AM
619_honda_boostn
Oct 16, 2008 04:14 PM
[Ennis_D]
Jul 18, 2008 08:37 AM
LilCivic04
May 27, 2005 05:07 AM
