Cracked sleeve question? Please Read!!!
Old Dec 11, 2003 | 02:12 PM
DRAGLS's Avatar
Default Cracked sleeve question? Please Read!!!
Modified by DRAGLS at 7:24 PM 1/5/2007
Old Dec 11, 2003 | 03:22 PM
SiRkid's Avatar
Default Re: Cracked sleeve question? Please Read!!! (DRAGLS)
when you let off, car goes lean.
so who knows how "quickly" this happens in your set up.
Old Dec 11, 2003 | 03:27 PM
baddassduramax's Avatar
Default Re: Cracked sleeve question? Please Read!!! (SiRkid)
how is he running 16lbs with hack
Old Dec 11, 2003 | 07:09 PM
dabrown's Avatar
Default Re: Cracked sleeve question? Please Read!!! (civicb18)
I don't think he is running the hack..
Old Dec 11, 2003 | 08:25 PM
tegmech's Avatar
maybe he did this https://honda-tech.com/zerothread?id=688903 . However, i am still skeptical about how well this actually works.
Old Dec 11, 2003 | 09:40 PM
earl's Avatar
Default Re: (tegmech)
It cracked because it leaned out at full throttle. Once you let off the throttle the damage was already done...you just didn't know it. Happens that way all the time.
Old Dec 11, 2003 | 10:52 PM
FastNFurious
Guest
Posts: n/a
He isn't running the hack, just using the s-afc to add/subtract fuel and also using a missing link or check valves.
I still don't understand how his sleeves cracked after he let off the gas?
How are you suppose to control that?
Slowly ease up on the throttle or what??
Old Dec 11, 2003 | 11:03 PM
earl's Avatar
Default Re: (David555)
why do I try?
Old Dec 12, 2003 | 01:15 AM
mskibbz-T's Avatar
Default Re: (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote"> why do I try?</TD></TR></TABLE>
LOL... Isn't it possible to cause preignition on decelleration after driving very hard. As fuel is cut back in accordance with your fuel maps as you let off the gas, the cylindrical temperatures are still extremely high and can cause preignition and cause some major damage even though you aren't full throttle. I read some domestic article on the issue, not sure if it applies directly since our methods of engine management are far more advanced than the typical domestic but I'm curious. Can decelleration fuel cut rates can play a role in causing engine damage after a hard run?
Old Dec 12, 2003 | 04:17 AM
rOby's Avatar
Default Re: (earl)
LOL
Old Dec 12, 2003 | 08:16 AM
earl's Avatar
Default Re: (mskibbz-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mskibbz-T &raquo;</TD></TR><TR><TD CLASS="quote">LOL... Isn't it possible to cause preignition on decelleration after driving very hard. As fuel is cut back in accordance with your fuel maps as you let off the gas, the cylindrical temperatures are still extremely high and can cause preignition and cause some major damage even though you aren't full throttle. I read some domestic article on the issue, not sure if it applies directly since our methods of engine management are far more advanced than the typical domestic but I'm curious. Can decelleration fuel cut rates can play a role in causing engine damage after a hard run?</TD></TR></TABLE>Great theory but it reality there is no load on the motor under deceleration. It is not working (making power). If the engine is working too hard under a lean condition acceleration (load), it will break. You just don't realize you hurt it until you are backing off the throttle.
Another way to look at it..when the engine is idle, even though it is way lean, it will not burn a piston. It will just shut off if there is not enough fuel. Why? Because it is not working under a load, not generating power.
Old Dec 12, 2003 | 09:59 AM
MotorMatrix.com's Avatar
I am a bad person
Default Re: (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">Great theory but it reality there is no load on the motor under deceleration. It is not working (making power). If the engine is working too hard under a lean condition acceleration (load), it will break. You just don't realize you hurt it until you are backing off the throttle.
Another way to look at it..when the engine is idle, even though it is way lean, it will not burn a piston. It will just shut off if there is not enough fuel. Why? Because it is not working under a load, not generating power.</TD></TR></TABLE>
good point earl. thats how you can get away at 17:1 idle ratios. and 14-15:1 cruising too.
Old Dec 12, 2003 | 10:29 AM
mskibbz-T's Avatar
Default Re: (earl)
Thanks for the clarification
What if throttle was reduced to say 50% after a hard run?
Old Dec 12, 2003 | 02:35 PM
99B16Si's Avatar
when i blew out my sleeve it was under hard acceleration in 4th gear, not letting off. it felt like i rear ended somebody it deccelerated so hard, i almost smacked my head on the steering wheel, good thing i wear my seatbelt
and its not like your block cracked out of no where im sure there were hairline cracks and stress fractures all over the walls that u were driving on for a while....sounds liek shitty tuning or the blaock had just seen its days if u ask me
Old Dec 12, 2003 | 04:42 PM
Ri5e's Avatar
Time for Hondata or AEM
Old Dec 12, 2003 | 04:57 PM
Jared's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAGLS &raquo;</TD></TR><TR><TD CLASS="quote">What do you guys think about having the block guard?bump^^</TD></TR></TABLE>
junk. blockguards are only good at making the tops of the cylinders hot. most cracks dont start at the top anyway
Old Dec 12, 2003 | 09:40 PM
nevin's Avatar
did you hammer it in?
Old Dec 13, 2003 | 07:59 AM
earl's Avatar
Default Re: (MotorMatrix.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MotorMatrix.com &raquo;</TD></TR><TR><TD CLASS="quote">
good point earl. thats how you can get away at 17:1 idle ratios. and 14-15:1 cruising too.</TD></TR></TABLE>Exactly my point
booboo782
Engine Management and Tuning
Feb 3, 2014 06:28 PM
thinknology
Jul 28, 2004 02:12 PM
adeihl
May 12, 2004 07:14 PM
MAD SOHC
Feb 4, 2004 01:59 PM
