cracked drag manifold
Old Jun 14, 2002 | 04:01 PM
bluebullet's Avatar
Default cracked drag manifold
I have a small hairline crack between the collectors I believe, what is the best way to have the fixed so it will be reliable, did a search could not finda anything. this is a drag gen III cast manifold.
Old Jun 14, 2002 | 04:04 PM
brian b's Avatar
New User
Default Re: cracked drag manifold (bluebullet)
i have a cracked rev-hard manifold.. id imagine the materials are similar.. ive asked a few places if they could weld it and they say the material is so inconsistant that it would crack all the way through if they tried to weld a small section
Old Jun 14, 2002 | 04:05 PM
int3gra's Avatar
Default Re: cracked drag manifold (brian b)
JB weld??
Old Jun 14, 2002 | 05:27 PM
zojirushi's Avatar
Default Re: cracked drag manifold (int3gra)
can't use jb weld, the manifold gets too hot for the stuff...
Old Jun 14, 2002 | 05:47 PM
ion_four's Avatar
Default Re: cracked drag manifold (zojirushi)
There is an epoxy made by Permatex, I think, that is for cracked manifolds...I've heard that it doesn't last forever, and it might be shorter on a high-temp turbo...there might be something, though.
Old Jun 14, 2002 | 06:23 PM
SIK IN DA HED's Avatar
New User
Default Re: cracked drag manifold (ion_four)
best bet might be to replace it.
Old Jun 14, 2002 | 07:35 PM
ninesecrx's Avatar
Default Re: cracked drag manifold (dlplayboy)
I had a huge crack down the middle of my cast iron rev-hard manifold back in the day. I just drilled the crack out clean so it cant spread more and welded inside it. Its not to hard, just gotta take it to a performance shop that welds......Mike
Old Jun 14, 2002 | 10:06 PM
DR. ON POINT's Avatar
Banned
Default Re: cracked drag manifold (ninesecrx)
send ben at importparts and email. I believe there is a lifetime waranty against cracks.
Old Jun 14, 2002 | 10:29 PM
johnmay19's Avatar
Default Re: cracked drag manifold (On Point EK!!!!!!!!)
I remember reading a reply from ben that if you crack one he will replace it for free.
Old Jun 14, 2002 | 10:48 PM
turbopimp's Avatar
Default Re: cracked drag manifold (johnmay19)
Yep, Ben at Import Parts offers lifetime warranty on DRAG manifolds....
Old Jun 14, 2002 | 10:54 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: cracked drag manifold (turbopimp)
Only if you bought it from Ben...
art
Old Jun 14, 2002 | 11:06 PM
quikrpm'z's Avatar
btw, were u using a flex pipe?
Old Jun 15, 2002 | 04:17 AM
turbo Si's Avatar
Default Re: cracked drag manifold (quikrpm)
Man you can't beat that. Who would upfront offer to replace a cracked turbo manifold. I'm glad I bought from Ben!
Old Jun 15, 2002 | 09:32 AM
FredoSP's Avatar
Default Re: cracked drag manifold (turbo Si)
BEN
Old Jun 15, 2002 | 10:53 AM
Anthony K's Avatar
New User
Flex pipe
hondaeg8
May 12, 2006 08:57 AM
hybrid901
Jun 18, 2002 07:55 AM
redteg1
Feb 6, 2002 08:29 AM
boosted3g
Sep 23, 2001 11:39 PM
VaporTrail
Jun 29, 2001 12:15 PM
