Correct PSI
Old Jan 15, 2006 | 11:26 PM
_k20a2_'s Avatar
Default Correct PSI
Firtst off some car info: I'm at 2200ft above sea level. I have a turbo RSX-S using Hondata K-Pro for engine managment and running off of a 9lb watsegate spring, 3" dp and true 3" straight through exhaust. Now in K-Pro you can read the map sensor to see what vaccum/pressure you are at, at full throttle my peak pressure according to the map is 9.2lbs. OK. Now at the same time my autometer boost guage is reading 11lbs. Which is right ? I figure one isn't conpensating for change in altitude above sea level/ barometric pressure. Is the guage correct and the MAP isn't compensating or is the MAP right and the gauge isn't compensating for the altitude ? Or another answer ?
Old Jan 16, 2006 | 08:11 AM
SOHFAST94's Avatar
Default Re: Correct PSI (_k20a2_)
Go with the K-pro. Those autometer gauges vary too much.
Old Jan 16, 2006 | 08:16 AM
splitime's Avatar
Default Re: Correct PSI (SOHFAST94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHFAST94 &raquo;</TD></TR><TR><TD CLASS="quote">Go with the K-pro. Those autometer gauges vary too much.</TD></TR></TABLE>
Agreed. My autometer is almost 3psi off from what my greddy profec is reading.
Old Jan 16, 2006 | 08:50 AM
adseguy's Avatar
Default Re: Correct PSI (splitime)
The GReddy profec is prolly a little off too . So is the ECU. Correct PSI is prolly the average of the map sensor, GReedy Profec and the boost gauge. With that I found that each sensor is off by about 1 - 2 PSI which is pretty normal IMO
Old Jan 16, 2006 | 08:55 AM
splitime's Avatar
Default Re: Correct PSI (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">The GReddy profec is prolly a little off too . So is the ECU. Correct PSI is prolly the average of the map sensor, GReedy Profec and the boost gauge. With that I found that each sensor is off by about 1 - 2 PSI which is pretty normal IMO</TD></TR></TABLE>
Heh, I trust it more than my autometer though
Old Jan 16, 2006 | 09:51 AM
adseguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime &raquo;</TD></TR><TR><TD CLASS="quote">
Heh, I trust it more than my autometer though </TD></TR></TABLE>
Mine seems to work fine, but I understand your point
Old Jan 16, 2006 | 10:14 AM
Importordomestic's Avatar
as long as you have barometric pressure compensation turned on in the ECU, the ecu is reading exaclty what it should be.
pkopalek
Engine Management and Tuning
Aug 2, 2013 10:07 AM
ballaownz
Aug 9, 2008 11:20 PM
Dartanian
Aug 31, 2007 06:04 AM
dunkd
Aug 6, 2005 11:10 AM
89dxhunchback
Nov 15, 2003 05:10 PM
