MAP sensor question
Old Aug 3, 2008 | 10:53 AM
ballaownz's Avatar
Default MAP sensor question
Hello people... please sry for the bad english, Im from brazil.
Im having problems with the boost pressure readings.
First of all, I changed the default map sensor to a motorola 2.5bar...
Tuned crome to read that sensor.
When I go to live tunning at crome, the pressure readings go from 5 to 6 PSI
But in my autotechnic boost meter, It shows 10-15 PSI
Both are linked to the same source.
Any ideas?
Old Aug 4, 2008 | 06:43 AM
ballaownz's Avatar
? nobody ?
Old Aug 4, 2008 | 08:38 AM
WrongWD's Avatar
First, I would double check to see that you have all the voltage values correct in Crome. Then, I would borrow a friend's other boost gauge, and test that to make sure yours is reading correctly.
Good luck!
Old Aug 9, 2008 | 11:20 PM
ballaownz's Avatar
ok, Ill do that... got another gauge... tx
GoHybrid
Mar 29, 2009 06:13 PM
ridin98civic
Oct 2, 2007 08:10 PM
the.hamburglar
Aug 4, 2007 08:39 AM
BoostGoneWild
Jan 17, 2006 11:16 AM
