correct gauge wiring for weldon db2015a.
Old May 24, 2007 | 02:54 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default correct gauge wiring for weldon db2015a.
ok i know about using the stock pump hot as the trigger for the relay. the question is, the weldon has 12ga on it to a pig tail. the terminals on the other side are 12ga. BUT, the power is coming from the front. i have not located my batt to the rear. (maz kill switch) the reason i ask, is my fuse holder is 12ga, i can get an 8ga amp kit with an 8ga barrel fuse. should i run 12ga front to back, or 8 ga front to back? no controller. mostly a track car.
thanks.
Old May 24, 2007 | 06:37 PM
vaporboy12's Avatar
Default Re: correct gauge wiring for weldon db2015a. (boostedcivicsir)
mikey i used all 10 ga on all my fuel pump wiring other than the trigger wire. which is 18ga with a 15amp fuse
Old May 25, 2007 | 03:55 AM
Mr. Badwrench
Default Re: correct gauge wiring for weldon db2015a. (vaporboy12)
10-4 imma call them just for s**ts and giggles today..
MrWhoopee
Jan 26, 2019 09:44 AM
ej1916
Jul 12, 2012 01:14 PM
prelude-all-the-way
Lighting
Jan 13, 2008 01:44 PM
boostedcivicsir
May 25, 2007 06:19 AM
ImprtTuner88
Oct 8, 2003 04:09 AM
