2002 Odyssey Front Washer Wiring - Honda-Tech - Honda Forum Discussion
Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Old 12-20-2018, 04:03 PM
MrWhoopee's Avatar
Default 2002 Odyssey Front Washer Wiring
My neighbor is repairing the front end of a 2002 Odyssey for an elderly friend after a front end crash. He has it all fully reassembled but is getting no voltage to the front windshield washer pump and can't seem to figure out which fusebox/fuse provides power to this circuit. Can anyone provide a schematic or link? I have found this https://www.autogenius.info/honda-od...e-box-diagram/
but none of the fuses seem to be assigned to the washer pump.
Edit: We've determined which fuse powers that circuit, it feeds the wipers too. The fuse is good and the wipers work. So now he needs the wiring diagram for the pump.
MrWhoopee is offline
Old 12-20-2018, 04:52 PM
Global Moderator
tech8's Avatar
Default Re: 2002 Odyssey Front Washer Wiring
For a 2002 Odyssey, Driver's side under-dash fuse no. 11 (10A) feeds power via the wiper/washer switch to the front washer motor.
tech8 is offline
Old 12-20-2018, 04:55 PM
MrWhoopee's Avatar
Yeah, we just found that. Fuse is good and wipers work. Need the wiring diagram from switch to pump.
Old 01-16-2019, 06:40 PM
P2K
I don't quite understand the need for wiring diagram for a 2 -3 wire pump motor. It should be either two wires power and ground. Or 3 wires and add the 5v reference. I recall just two wires, but I'm not standing there. Just jump power to one pin and ground the other pin.
P2K is offline
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
